Old 12/15/09, 10:18 PM
Robert Sole's Avatar
Robert Sole Robert Sole is offline
Default Name that roof?
I am looking or the correct terminology of the roofing used on many low slope roofs here in Florida.
I have watched it installed numerous times. They start with a double layer of 15# roofing felt and then hot mop what appears to be 90# mineral surface roll roofing over it. Typically they will apply the hot tar and lay the first layer even with the eaves, place the second layer over it to align it with an exposure of about 18", and fold it down. They mop the area under where the top of the strip will go with tar, lay it back down and fold the lower part back over the top. They then mop the underside of that layer and lay it back down to seal on the layer below. The better roofers will sprinkle matching granules over any tar that is exposed.
What is the correct name for this type of roof?
Robert Sole, CMI
407-637-7288
Florida license numbers HI 169 and MRSA 92
Serving the Orlando Florida area including Orange, Seminole, Northern Osceola and Southwestern Volusia Counties.
RobertSole@REMinspections.com
Check out my blog orlandohomeinspections.info/
REMinspections.com
OrlandoHomeInspector.net
Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America)
Old 12/15/09, 11:10 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
Default Re: Name that roof?
we call it built up/hot mop..hope that helps
Old 12/15/09, 11:47 PM
The built-up roofing I am familiar with is 3 or more layers of 30# felt with each layer hot mopped down and is usually coated on the surface. With the roofing I am talking about, only the 90# (or at least that is what it looks like) is the only thing mopped down.
A roofing contractor told me that it was modified bitumen, but when I researched that, it didn't sound right either.
BTW, I said 15# in the first post but meant 30#.
Robert Sole, CMI
407-637-7288
REMinspections.com
Old 12/16/09, 12:43 AM
modified is a rubber like roof that you heat up with a torch and stick down. It close to like a 90#cap sheet. Modified has a granule or smooth surface. Built up can be 1 ply up to 5 or more plys...do you have photos of them. If I saw a photo I can say for sure what your looking at.
Old 12/16/09, 12:47 AM
the plys are just an underlayment, on built up you would cap the plys with a cap sheet of some type.
Old 12/16/09, 1:49 AM
Maybe I have been calling them the wrong names for a while. Don't know how well you can see things in the photo, but the first one is what I am talking about. The second photo is what I am used to calling a built up roof.
Robert Sole, CMI
407-637-7288
REMinspections.com
Old 12/16/09, 4:07 AM
Pic #2 looks like a built up hard to tell because it has a coating applied over the top of it. Looks like an aluminum type coating. is #1 the same roof as #2?
Old 12/16/09, 11:17 AM
rbero rbero is offline
Send a message via Yahoo to rbero
pic 1 is rolled roofing
Old 12/16/09, 12:18 PM
Doug Edwards's Avatar
Looks like the first photo to be "selvage" roofing. The material only has half of the base material covered in mineral with the other half having the exposed base material suitable for sealing with the tar. This basically gives double coverage as one half of the next layer overlaps half of the previous course. They do use it alot in FL particularly on shed style, low pitched roofs (sunrooms, etc). More often than not I see rolled roofing with only about a 6 inch overlap. This costs a lot less but does not give nearly the protection and coverage. Lots of people, including roofers use the two terms interchangeably. Based on what I can see is they used rolled roofing (top course is completely covered with mineral) but did it in the style of selvage by overlapping by half the width.
- John Stuart Mill
Old 12/16/09, 1:47 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
The terms I am familiar with in my area: Neither are recommended around here:
Rolled Roofing
Half Lap
Old 12/16/09, 2:54 PM
This link may help on the subject.
http://www.wbdg.org/design/env_roofing.php
Old 12/16/09, 9:13 PM
gbeaumont's Avatar
Give that man a cigar, it's commonly called "wide selvage" roofing
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 12/16/09, 9:32 PM
They must have flooded the roof with asphalt to make this product look like a BUR.
Used to install this crap as a kid. Unfortunately they still sell it.
Old 12/16/09, 9:37 PM
Regards
Gerry
A good cigar and a couple of cold long necks sounds good right now.
- John Stuart Mill
Old 12/17/09, 9:28 AM
Mark S. Tyson Mark S. Tyson is offline
there are many common names for this system, but if you to use the same terminology as the building code it would be called a " coal-tar built up roof"
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
