| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
Would you say this roof is near the end of its life? Its only 14 years old. There was some minor water staining on a couple of trusses in the attic.
Looks OK to me. A cedar shingle roof should last a whole lot longer than 14 years.
It looks like it needs some maintenance, which is a constant on wood roofs but there are many variables for life expectancy.
____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Mark,
Is this the same roof you have questioned about in another thread? Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network What we've got here is......failure......to communicate.....
Looks good. Note the thickness of the shingle. Good.
BEN GROMICKO Director of InterNACHI Online Education President of NACHI.TV - Online Training Videos President of Mountain Warranty Corporation ben@nachi.tv (303)862-2611 ben@mountainwarranty.com IMPROVE YOUR REPORT |
Steven Waskewicz Rest Assured Inspection Services, LLC. 12615 Halleluiah Trail Elbert, Colorado 80106 Office 719-510-7703 mobile all the time Fax 719-495-7166 Serving Colorado Springs, and surrounding areas. www.restassuredinspection.com s_waskewicz@msn.com NACHIiid=NACHI06032370 |
Looks fine. With shakes, you're looking for widespread decay, usually at the butts, shakes worn thin and eroded through in places with underlayment showing through holes from erosion and weathering. Also many big splits that expose underlayment and create minimum sidelap problems (1 1/2" minimum).
Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
Physically the roof looks good. Though the look of the shingles suggests a need for maintenance to me. Without maintenance the lifespan can be greatly reduced.
Were the stains on the trusses active? If not or it was dry I would recommend monitoring during a rain storm just to be sure. Don Belmont email: don@wisehi.com Are your home inspections priced for profit? The Service Business Profit Pricing Modeler can answer that question. Easy, Fast, Accurate, Affordable Special Pricing for InterNACHI members. Send me a Private Message for the discount code. WiseEyes Home and Property Inspections Inc. Vermont Equine Thermal Imaging Vermont Home Energy Tune-up |
Looks good from here. Just needs some maintenance as others have stated above.
Gerry Pallotta Alota Home Inspection Services www.alotahomeinspect.ca Greater Toronto Area Home Inspector Mississauga Home Inspector |
Some of the ridge shingles look bad, but the rest seem fine from the photos.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
Steven C. Meyer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thank goodness this was about a roof, and not about me or other of us that visit this board that are "age challenged"!!
14 years old? Are you sure? Should last longer than that. My cedar roof in central Oregon lasted by a little over 30 years. Finally replaced it, was at the end of its useful life (it had a "living will"), and wanted a fire resistant roof system due to forest fires. Depending on when it was installed, your climant. determines the life span of cedar, and newer cedar is not quite as thick, as those of years ago. My advice, have a roofer inspect and certify the remaining life span of the roof. Unless the roof is newer, of in obvious good condition, I defer that (and the liability) to a roofer. |
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
Many of us are age challenged (I get social security and medicare). One thing about newer cedar shingles/shakes; they are just as thick as the older ones. The difference is that the resins in the old growth cedar are more concentrated than what is now available (second growth stuff).
| Imagine There's A Heaven | jmckenna1 | Misc. Discussion | 3 | 12/24/07 12:15 AM |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical | 9 | 4/18/07 8:22 PM |
| NNC Members get Life Membership with NHITI | jbowman | Misc. Discussion | 24 | 2/28/07 8:43 AM |
