Old 12/2/06, 5:23 PM
Christopher S. DeWitt's Avatar
Christopher S. DeWitt Christopher S. DeWitt is offline
Send a message via Skype™ to cdewitt
Default Need to ID type of stucco
home built 2003, has details that are slope to prevent water pooling on flat surfaces, has kick out flashing. Looks to be a thin coat stucco 3/8 inch or so. My concern is the cracks over the front door. Plus, I found the under a bay window in the front the stucco has no weep in the front and is stucco under the bay window back to the house.
Also, there is no caulking around any window or door opening, I'm not sure if is required or not. the stucco goes right up to the window frame but there is a gap of about an 1/8 to 1/16 of inch around the windows, there is metal flashing over the top of the window frame.
Any help would be great, I'll get photos up when I find my adapter cord.
Thanks
A2Z Property Inspections
Christopher De Witt
612.270.2957
Old 12/2/06, 9:03 PM
Default Re: Need to ID type of stucco
Gotta' have caulking around penetrations like doors and windows. Gotta' have something at the bottom wall termination to seal the wall assembly but still allow moisture to escape from behind the stucco. Like Weep Screed!
Old 12/3/06, 7:42 AM
Carl A. Brown's Avatar
If there is no backer rod and sealant joints around the windows and doors they also are not installed to the mfgrs. specs. It voids the warranty on them.
Some of the onecote systems as you are implying do not call for weepscreed they call for a weeping caseing bead that has holes in the bottom of it! And the one cote systems are put on very thin.
But there needs to be backer rod and sealant joints around all penetrations according to ASTM specs for it to be properly installed!
ASTM C 926 ASTM C 1063
Of all places Minnesota
http://www.mnlath-plaster.com/listin...esidConstr.pdf
Several links for window info!
http://www.badstucco.com/phpbb/viewf...20bdaec4ea1523
If you are looking during the construction phase!
http://www.mnlath-plaster.com/listin...oChecklist.pdf
Info and comments on onecote stucco,
http://www.badstucco.com/phpbb/viewforum.php?f=4
Old 12/3/06, 9:36 AM
Russel Ray's Avatar
Originally Posted by cbrown1
"File is damaged and could not be repaired."
Old 12/3/06, 9:40 AM
It worked for me just now.
Old 12/3/06, 12:35 PM
I'm looking for a good illustration to include in my reports showing the proper lower wall termination for EIFS. Around here. they never use anything. Anyone got one they'd like to share? (couldn't copy the PDF's)
Old 12/3/06, 12:47 PM
Russel Ray's Avatar
Instead of "copy," try "File save as."
Here's another guide that I have stored at About Homes:
About Homes 0097
Old 12/3/06, 1:08 PM
About Homes 0097
Thanks Russel, I can save the file, I just can't cut out the illustration.
Old 12/3/06, 1:45 PM
Russel Ray's Avatar
Take a screen shot (usually SHIFT PRTSCN), then open any photo editing software, paste the screen shot in there (SHIFT INSERT or CONTROL V), modify as necessary, and save.
Old 12/3/06, 2:08 PM
Barry Adair's Avatar
sto has one of the best libraries I've found. jpeg pdf autocad
This is one brand of residential, there are others and commercial applications.
You'll have to search for your system type.
http://www.stocorp.com/allweb.nsf/deteifs#2
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/3/06, 2:12 PM
Yeah, I know now you have to disclaim that the photos are not the brand system that is installed on the subject property. Unless it is then it's copy and paste.
Everything comes with a price.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/3/06, 5:04 PM
System Components
Old 12/3/06, 5:11 PM
http://www.mnlath-plaster.com/listing/EIFSDesign101.pdf
Old 12/3/06, 5:23 PM
Thanks
http://www.nocsa.org/faq.htm
http://www.masterwall.com/One%20Coat...o%20(OCS).html
http://www.aecdaily.com/en/1587446
Hope this helps.
Marcel
Old 12/3/06, 5:47 PM
Alright you guys, stop being so intimidating will you. I am just trying to help.
Kenton Shepard, NACHI member # 04082383
Peak to Prairie Inspection Service
2020 20th St. Boulder, CO
(303) 258-8289
Log Home Inspection
Straw Bale Home Inspection
Concrete Home Inspection
Earthen Home Inspection
Inspection in Mexico
www.peaktoprairie.com
ADAIR INSPECTION
BARRY ADAIR Owner-Inspector-Moisture Analyst
TREC # 4563
NACHI 04080595
GARLAND, TX 75042
http://www.adairinspection.com
Doing the best I can to help, OK?
Marcel
Fire rating abolt Structural Inspections 13 9/21/07 8:45 PM
Stucco course badair Inspection Education & Training 2 11/21/06 5:51 PM
Wisconsin stucco problem dnice Exterior Inspections 6 10/17/06 8:03 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
