Ran across this situation today on a new construction pre purchase inspection. Property is a townhome. They are in the last phase so most likely others of the same design have been done.
In the photos you are looking at the roof from on the roof. The area with the arrows slopes two ways. One across the arrow left to right as you would expect. Two it also slopes with the arrow. It seems to me that the slope with the arrow will run water across the shingles from side to side. Would this not be a potential point of water intrusion? As the roof is finished I could not see under the shingles to determine if special precautions were taken, but I doubt any would be. Opinions? Is this a potential problem? If so, how would you call it out? Thanks in advance. Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
Kevin, from what I can see in the pictures, I do not see a problem
Steve McIntire, Inspector EEinspections.com |
I would say 3-Tabs shingles are designed to be installed horizontally, not vertically, therefore leaks may occur in the future.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
vertical shingles?
If that valley was continuous and the shingles were weaved correctly I wouldn't think it would be a problem, but their not. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Kevin,
Hard to tell but this looks like a framing problem. Why is there an offset valley, hump, doubled up shingles, and fish mouth intersection? Do you have a picture showing an exploded view of this area of the house? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Obvious to me also, that who ever installed this roofing did not know how to weave a valley properly, and usually when you weave a valley, it starts at the bottom correctly and goes all the way up, and not switch to a cut valley after this discover they do not know how to weave the roofing properly.
Needs to be refereed to a qualified roofer for evaluation. Marcel </IMG></IMG> |
dthomas2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kevin,
Could you please give us some more on these shingles? They do appear upside down. Are there more than three tabs per shingle? Very different looking stuff. |
I do not inspect roofs on townhomes. The Homeowners Association is responsible for the roof repairs or replacement. Same with condos.
Helm Home Inspection David Helm, Owner/Inspector http//www.helmhomeinspections.com |
Think there is going to be a real problem here as well as those other issues mentioned regarding the irregular roof sheathing, change of methods, etc...
Thanks for the input.
I recommended further evaluation by a licensed roofer. I don't have another good picutre of the area from further away. Here is one looking down from the top. Even though it is a Condo/Townhome, I think the potential buyer should know about a potential problem, particualrly when it is new construction. Around here the builder is typically responsible for the first year then it transitions to the HOA. Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
Thanks again for the feedback. You guys confirmed my thoughts. Professional Inspector Level I Infrared www.AbsoluteInspections.net www.homeinspectorsplanotx.com www.homeinspectorsmckinney.com Absolute Inspections, LLC 972-463-0887 |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/24/09 12:52 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
