Old 6/6/07, 9:56 AM
mporras mporras is offline
Please Note: mporras is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Need Vinyl Siding Help
Hello everybody,
Is there more to write about this, other than the improper clearance to grade. (Less than 1/2 inch in some areas.) Shouldn't the exposed sheathing be protected from water, termites, etc? Shouldn't the sheathing be flush with the stem wall, and flashed? What am I missing? Any suggestions are greatly appreciated.
Old 6/6/07, 10:08 AM
Joseph Hagarty,  CMI's Avatar
Default Re: Need Vinyl Siding Help
http://www.vinylsiding.org/publicati...al_english.pdf
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/6/07, 10:16 AM
Thanks Joseph,
I found that as well, and quickly skimmed through it. I am trying to get a report out right now, and plan on studying that after I'm done. I was just looking for some quick advice so I can send the report out.
Old 6/6/07, 10:22 AM
- Note the deficiency.
- Identify the potential for weater damage to the sheathing below the bottom edge of the siding.
- Recommend further review and repair as needed to alleviate the potential for water intrusion.
Joseph P. Hagarty
Phone: 610-399-3675
Old 6/14/07, 5:13 PM
rstringer rstringer is offline
I looks as if the old blue tarp was taken off of the lawn mower & used as vapor barrier??? I would always report the raw wood exposed to the elements, this condition won't get better with time.
Old 6/26/07, 7:06 PM
Christopher T. Bates Christopher T. Bates is offline
Vinyl siding is supposed to have a starter strip that the lower siding "lip" will connect to. It would have been the same color as the corner trim and the soffits. There was a major shortcut made here that would most likely void any manufacturers warranty as it was improperly installed. Any exposed sheathing as you have in the picture is a big no no. It almost looks as if they meant to come back and add the starter strip later having left room for it to be nailed to the bottom plate, but then never got around to it.
Old 7/2/07, 10:43 PM
sgreen2 sgreen2 is offline
The tarp like material is a house wrapp. Starter strip is already on. If it wasn't , that bottom course of siding would not be tight to the sheeting. Stater strips come in different materials(aluminum , steel , galv. , and vinyl. Color and shapes vary. Looking at your picture , I've seen this many times over the 30 years in the siding business. It's poor workmanship. Either the sheating is to low , or the siding is too high. Scott
Do you unzip vinyl siding? apfaff Exterior Inspections 13 7/23/08 8:49 AM
Vinyl siding rmacinnes Exterior Inspections 18 9/27/07 12:00 PM
ALCOA vinyl siding one side warping, why? Lynn Kelly General Inspection Discussion 4 5/23/07 4:32 PM
Vinyl siding window trim jclark1 Exterior Inspections 14 6/6/06 9:46 PM
Vinyl Siding Install psmothers Exterior Inspections 3 4/21/06 2:44 PM
