Old 1/11/07, 11:23 PM
Joe Funderburk, CMI's Avatar
Default New Construction & No Weep Holes
$800,000 custom house. Brick and stone veneer. No weep holes. Has been under construction for 1 year. Not yet occupied. See the pics of water damage.
P.S. Are weep holes required for stone veneer? Didn't see them there either.
ID:	8328 new-construction-and-no-weep-holes-011107-001-small-.jpg.jpg
ID:	8329 new-construction-and-no-weep-holes-011107-093-small-.jpg.jpg
ID:	8330 new-construction-and-no-weep-holes-011107-105-small-.jpg.jpg
ID:	8331 new-construction-and-no-weep-holes-011107-094-small-.jpg.jpg
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 1/12/07, 12:10 AM
Bob Givens Bob Givens is offline
Send a message via AIM to Bob Givens
Please Note: Bob Givens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: New Construction & No Weep Holes
Cultured Stone® Online
Flashing Products - Manufactured Roof and Pan Flashing Components
This may help
Bob Givens
Old 1/12/07, 1:01 AM
I don't think this is cultured stone. Weep holes required in a wall like this?
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/12/07, 7:40 AM
Attachment 8328 Attachment 8329 Attachment 8330 Attachment 8331 Attachment 8332
http://www.luckstone.com/arch/design...tics/index.php#
Maybe some of these details will help.
Marcel
Old 1/12/07, 11:32 AM
Carl A. Brown's Avatar
What is on the house for moisture barrier?
And at what location did you find the moisture! Under a window maybe?
Old 1/12/07, 6:51 PM
ldapkus ldapkus is offline
Joe,
I saw one today and checked it out. It had weep wicks every 8 feet.
ID:	8345   new-construction-and-no-weep-holes-p1120084-small-.jpg.JPG
ID:	8346   new-construction-and-no-weep-holes-p1120085-small-.jpg.JPG
Old 1/12/07, 10:44 PM
Originally Posted by ldapkus
Joe,
Ah yes, the old witch, ah I mean the old cotton wick.
Yep, I remember those, actually they old wick oil lanterns used to work pretty good with those.
The only problem with the wicks is that people kept leaving them in and not pulling them out.
The whole concept was to use the wick when starting the masonry, and at the end of the day or during, they get pulled out. Thus creating a tubular hole to let the moisture out.
But, you always get the crowd that fails to follow through. Oh well. what can you do.
Hire a NACHI Inspector to educate the Clients.
Marcel
Old 1/15/07, 12:58 AM
William J. Decker's Avatar
I that an OSB sill plate? That ought to explain alot.
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 1/15/07, 1:07 AM
No. The OSB was the wall sheathing. The sill plate only existed over the pilasters and you can see a bit of them in the corners of photo 3 & 4.
Related note: I did a 10 year old beautiful home Saturday. All brick with no weep holes. The band sill was BADLY decayed at the entire perimeter of the house. Decay spread to the joists where they join the sill. The foundation vents were open and even the wood over those vents was wet to the touch. I felt sorry for the seller because he kept the house under a bond with a termite company and was ill served by that company.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/15/07, 11:52 PM
The buyer called me tonight and asked my advice. She also said the builder offerred to drill holes in the brick to create weep holes (now we all know that won't work). Here were her questions:
1) Should she have the drywall cut out in places to look for mold on the interior walls?
2) Should she hire a mold remediation specialist?
I told her that the source of the problem needed to be identified 1st. I don't think cutting out the sheetrock to search for mold is the right thing to do at this point. I don't think a mold specialist is called for at this point. What do you guys think about thermal imaging? Is that a tool that could be used to find out how extensive the moisture damage is behind the walls?
Any thoughts are appreciated as to how to determine how extensive the problem is and how to fix it.
Theodore Roosevelt
Joe Funderburk, CMI
Old 1/16/07, 7:19 AM
http://buildscanir.com/index.php
Old 1/16/07, 11:55 AM
Iaqforum Deuitch Iaqforum Deuitch is offline
Please Note: Iaqforum Deuitch is a non-member guest and is in no way affiliated with InterNACHI or its members.
A few issues here. Thermal imaging is a good tool but not perfect. It can only see temperature anomalies on surfaces. Additionally, it can be masked by solar loading and other factors. None the less it is a good place to start and I love my IR Camera, a FLIR B-2. Thermal anomalies are verified using conventional moisture measuring devices. What ever technique is implemented, you are quite correct in needing to isolate the source of the moisture intrusion prior to remediation. The only exception to this is if reasonable evidence exists for high airborne spore levels, then sampling will give an idea as to the livability of the structure. But please understand, no exposure standards, to my knowledge, presently exist and this is the topic of considerable debate.
I would caution about cutting large holes to gain visibility. This will allow for a large infiltration of spores into the interior environment if the holes are cut from the interior. My preference is for the use of a micro-video camera. I am not too keen on borescopes since the depth of field is pretty poor. A Snakeye video camera system is pretty good for inspecting wall cavities with only about a 1 inch diameter hole for insertion.
For more opinions on this issue, you can post your questions on the Indoor Air Quality forum at www.iaqforum.net
Thanks.
Jeff Deuitch
Microbiologist
The IAQ Forum
www.iaqforum.net
Old 2/1/07, 12:43 PM
I got a call from the client today. (She is also a big time Realtor.) She sincerely thanked me for the thorough inspection. She said I "saved her life" as she has breathing problems and thought the potential mold issues would be a concern.
She said she did not use infrared, as I recommended. She had holes cut in the walls. She said that the OSB was wet and black to within 6 inches of the 1st floor ceiling. When I asked what the builder was doing about it, she said he had fans blowing on the walls to dry it out. (Sound's questionable since not all the sheetrock was removed.) She asked me what I thought about that. I said, "would you knowingly build a house with water damaged, black OSB?" She said, "no". I said, "Neither would I."
Told her issues to consider: 1) they need to figure out the cause of the problem, as the condition existed in several areas behind the stone and brick. 2) Was the wood too heavily damaged to be used in its current condition? 3) Would there be a potential mold issue if things weren't thoroughly dried out?
I asked her how the water was getting in, and she wasn't sure.
My advice: hire an independent consultant to review the building method and the builder's plans for correction. Gave her the name of a GC and a Structural Engineer.
Feel sorry for her. It's her property--lake front beautiful lot. Custom house. She can't "back out of the deal."
Right track with my recommendations?
Theodore Roosevelt
Joe Funderburk, CMI
Old 10/19/08, 10:21 PM
Peter W. Bennett Peter W. Bennett is offline
Can't back out? Sure can, on the grounds of breach of contract, i.e., not built according to manufacturer's spec's.
Old 10/19/08, 11:18 PM
Yep. Manufacturers and architect and builder's plans.
Will Decker, CMI
Question about weep holes. gromicko Exterior Inspections 10 1/28/08 11:25 AM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 7:45 PM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 10:20 AM
