Old 6/29/14, 11:34 PM
Nick Gromicko's Avatar
InterNACHI Admin
Default New patent for deck baluster bracket.
http://www.nachi.org/documents2012/US20140082921A1.pdf
President, Contractors Association
Author, How to Run a Successful Home Inspection Business
Founder, InterNACHI
Owner,Nick Gromicko General Contractor
"Just as iron sharpens iron, one man sharpens another."- Proverbs 27:17
Planet InterNACHI.... resistance is futile.
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/30/14, 6:39 AM
John Paul de Oliveira's Avatar
John Paul de Oliveira John Paul de Oliveira is offline
Default Re: New patent for deck baluster bracket.
It seems to have some advantages. One drawback can be designed out.
He got his 20 claims in
John Paul Lucas de Oliveira
Home Sight Inspection, LLC
AHIT / GB-2 #86934 / AB #44580 / PMC #63299
Albuquerque, Rio Rancho, Edgewood, Placitas, Los Lunas, East Mountain Areas
505-620-4439
http://homesightinspection.com
into alternative engines?
check out: http://lucasengine.com
Old 6/30/14, 9:13 AM
Paul Lesieur's Avatar
Paul Lesieur Paul Lesieur is offline
Not very attractive.
Mpls/ St Paul home inspections
http://silvertreeinspections.com/
203K Loan Consultant Minnesota
Level 1 Thermographer
Old 6/30/14, 11:39 AM
Frank Rotte's Avatar
Frank Rotte Frank Rotte is online now
That's revolutionary?
Old 7/2/14, 7:57 PM
vadams vadams is offline
InterNACHI Vendor
Frank,
Most certainly...all available 2" X 2" steel brackets or screws rigidly affix the baluster to the lower deck rail. Wood baluster shrinkage and subsequent moisture expansion leads to structural failure and potential loss of life and limb resulting from falls from failed balusters.
The Slip Tie Connector at the lower rail allows for vertical movement while maintaining its structural integrity.
Old 7/2/14, 8:03 PM
InterNACHI Vendor
I would be interested in knowing more about your "one drawback can be designed out"
Could you elaborate?
Old 7/2/14, 8:04 PM
Sean Fogarty's Avatar
Originally Posted by vadams View Post
Frank,
Huh?? Structural Failure of what? I have looked at hundreds if not well over 1000 decks at this point, and the only thing I find is broken or rotted ballusters. NO structural failure and no hazards to life or limb. Its not real difficult to replace an .86 cent balluster. If all that holds the railing on is ballusters, then it's wrong to begin with.
Personally, all that metal attached to the entire surround of the deck would probably be an eyesore IMO.
By the time the ballusters are becoming a hazard to life or limb, so is the rest of the deck.
Fogarty Inspection Services Group of Palm Bay FL
Florida Licensed Home Inspector #8351
Home inspections, Commercial Inspections, Thermal Imaging, Wind Mitigation and Insurance Inspections for Palm Bay, Melbourne, Cocoa, Titusville, Vero Beach and all the surrounding areas.
321-506-5125
[email protected]
www.homeinspectorpalmbay.com
Old 7/2/14, 8:31 PM
Larry Kage, CMI Larry Kage, CMI is offline
I heard from a friend, whose daughter was on a second story apartment deck, and her toddler "staggered" over toward the edge railing to pick up a ball and stumbled/fell forward hitting his head directly on one baluster which gave way because it was rotten and split. The two, on either side of that one at 4" apart, held as his shoulders hit them. Otherwise, he would have gone down 8 to 10 feet to the ground whatever was below.
Apparently, it was old, cracked (where the air gun slammed 2 or 3 nails into it) and painted over with several coats.
Most every deck I see has some kind of potential hazardous safety issue.
Larry Kage, CMI
whis11 @ charter.net
The above post represents my personal opinion.
Old 7/2/14, 8:35 PM
I wonder how old the deck was??? Even with a metal clip at the base, the top still needs securing and still could crack. Clip or no clip, something 20 years old is goung to be pretty rough.
321-506-5125
[email protected]
Old 7/2/14, 8:58 PM
Juan C. Jimenez Juan C. Jimenez is offline
That is a bit excessive isn't it?
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Chesterfield Home Inspector
Petersburg Home Inspector
Richmond Radon Testing
Old 7/2/14, 9:46 PM
InterNACHI Admin
Larry writes:
That has been my experience as well.
Founder, InterNACHI
Draft RESNET Standard now open for public comment John Snell Thermal Imaging, Infrared Cameras & Energy Audits 169 7/2/09 2:43 PM
Latent and Patent Defects gpallotta Canadian Inspectors 5 11/25/06 5:42 PM
