Old 7/29/09, 11:59 AM
Mitch Patel Mitch Patel is offline
Please Note: Mitch Patel is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default ** New Roof in question! Need Advise!
I had a new 30 yr GAF Architectural roof installed. The roof is not done right.
The Shingles have been nailed high above the marked line. The line is the guide for nailing which lets the nail penetrate the laminate of the shingle. Nails are typically about 1” to 1.5” above the line. There is a 16 to 20 inch gap between nails. The nails are overdriven. Also when they cut the ridge on top of the garage the plywood was damaged. Hence no place for nails to go through. Also some missing nails on the ridge cap.
I am looking for some advise.
Any input is much appreciated.
Thanks
Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America)
Old 7/30/09, 10:55 AM
Default Re: ** New Roof in question! Need Advise!
Thanks
Arm yourself with a copy of the manufacturer's installation recommendations (you can download them from the GAF website)and call the contractor who installed the shingles. They need to make it right. Overdriven and improperly-placed fasteners will reduce the wind resistance of the shingle roof, no question.
Placing nails in the adhesive strip will compromise the bond. An adequately-sealed adhesive strip bond is very important to wind resistance. They may be able to hand-seal affected shingles after re-nailing shingles correctly.
Better if they can correct the problems before the adhesive strips bond. If they don't and the adhesive strips have already bonded, the bonds will have to be broken on all the shingles and all shingles should then be hand-sealed to ensure a good bond.
You should confirm my advice with GAF tech support. I'd e-mail their tech support so that you have their response in writing.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 7/30/09, 1:39 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
^What he said^
Part of the reasoning for nailing on the line, is so the layer underneath has another set of nails in it. If they are consistently riding high, they are only getting HALF the recommended nailing.
Old 7/30/09, 2:00 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Stop the check!!!!
www.MauiHomeInspections.com
Old 7/30/09, 8:52 PM
wsiegel wsiegel is offline
Call the manufacturer. They should have a rep in your area. He will come out and check the installation.
Old 7/31/09, 12:01 AM
If you can do this, it's great. the least amount of arguing on your part, the most credibility.
I want to know if the manufacturer really will send a rep.
Mitch, please post if they do!
(303) 717-8940
Old 7/31/09, 12:07 AM
Paul Pendley Paul Pendley is offline
I agree with Stop the Check!!! If your not satisfied with your contractor then do something about it. If your not sure about the installation methods then have it evaluated by another contractor then take action.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 7/31/09, 1:06 AM
I agree with "stop the check" too. I had assumed it was too late. If it's not... get all the leverage you can.
(303) 717-8940
Old 7/31/09, 1:13 AM
If your in CA i can help you with that ...but we dont know where your from.
Paul Pendley
866-458-8516
Old 7/31/09, 8:54 AM
I am in CT. Payment made via Credit card.
Thanks
Old 8/9/09, 11:57 AM
lfoster's Avatar
lfoster lfoster is offline
You should be able to put a payment hold thru the credit card company. Explain the reasons (probably need to be in writing) to the cc company and see what they tell you !
Good luck,
Old 8/9/09, 11:25 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
Thanks
Just curious.........did you go with the cheapest bid.............that is where most problems start.
Old 8/10/09, 6:16 AM
Peter C. Russell's Avatar
Yup, your sure got that right!!!
Old 8/10/09, 11:40 PM
Not the cheapest guy. Second cheapest guy. Check BBB and the references.
Also the town requires you to pull permit. They do not come by to check the job while its going on or after. Amazing!
Old 8/14/09, 7:45 PM
Second question.............how many of them spoke english?
Roof question mashburn Exterior Inspections 23 12/16/07 7:14 PM
Roof structure question adooley Exterior Inspections 13 2/19/07 12:29 PM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
Wood shake roof question jclark1 Exterior Inspections 4 9/11/06 9:23 PM
