Take a look...nice house and the deck was very sturdy.
The ledger board was not bolted...... ![]() ![]() ![]() ![]() Here's the way the ledger board is secured to the house. ![]()
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like a roof, not a deck. Should be bolted like a deck in my opinion.
I should have said Patio.
That is also the "opinion" of the CA Building Code.
The ledger must be bolted and the framing hardware must be bolted. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks for the reply....Im going to write it up.
Be careful David I have seen this before. Sometimes for added protection the 2x8 has a protected board over the bolts. Since this cannot be confirmed it is best to note this in the report when you write it up.
The only way to determine this is with removal of the protection board. Problem is that it is nailed and will need to be checked by the owner of the home by prying the board away in one area to see if there are some lag bolts. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Good catch, Kevin!
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
I considered that as well, however, the lack of bolts at the framing hardware is enough to defer the installation for correction.
And what data would you resource? The structure appears too be fairly new. if aft-were a pubic records search that finds the structure badoo or in compliance Mark S. Tyson M Tyson construction LLC Tyson Home Inspections Certified General Contractor #1516843 Florida Licensed Home Inspector #1824 Member N.A.C.H.I. IAC2 certified Member Florida Building Officials Association http://www.TysonHomeInspections.com |
CA is in Seismic Design Category (SDC) D&E for most of the state. Column bases, beam seats and ledger boards all require positive anchoring. This is generally achieved with through-bolts and/or lag-bolts. For the most part, nails do not provide the anchoring required in the higher SDC zones. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I agree it needs repair and bolts.
Not to stir the pot anymore... but the cantilever could have been an issue for many *standard* handouts (.pdf file). Most load paths are due-vertical on the deck/patio cover handouts I've seen and if a patio cover or deck is outside of the spans and configurations, this could indicate that the design would have been engineered. I would have still mentioned the obvious, as the structure lacked connection, but may have leaned toward telling the buyer to seek additional information. The individual AHJ may have approved... just a thought.
*edit* - Also, the second span from left in front of the windows looks a weeee bit far for what looks like 4x8 Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 5/14/11 at 1:18 AM.. Reason: edit |
I doubt he approved those footers.
What's a footer? Oh, you mean footing
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Nice looking deck | ccurrins | Exterior Inspections | 10 | 3/15/11 11:30 AM |
| Vent in Ledger Board | jnicholson | Exterior Inspections | 17 | 5/24/06 5:29 PM |
| New Hampshire Real Estate Agents Are Upset! | fcarrio | General Inspection Discussion | 8 | 2/11/06 1:35 PM |
| No Ashi / Nachi Conflict!! | fcarrio | Legislation, Licensing & Legal Issues for Inspectors | 5 | 2/11/06 1:32 PM |
