Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 8/18/08, 7:00 PM
Ronald G. Chorey II's Avatar
Ronald G. Chorey II Ronald G. Chorey II is offline
Default No weep screed
Anyone know how to (if possible) add weep screed after the fact. New Mexico (or Las Cruces) did not require weep screed prior to 2005 (I think). My own home had the stucco installed to grade. I have trenched around to get the soil/sand away from the stucco as it is wicking up when it rains. I would like to add sidewalks around the home but want to make sure I do not damage the stucco in the process. Anyone with any ideas? Thanks
Old 8/18/08, 7:29 PM
Carl Brown's Avatar
Carl Brown Carl Brown is offline
Default Re: No weep screed
Got a plane ticket??
Old 8/18/08, 9:10 PM
Barry Adair's Avatar
Undermining the foundation does not sound good
Pictures would help
Make that 2 tickets
Carl's always helpful
badair
ADAIR INSPECTION
972-487-5634
Residential-Commercial-Construction-EIFS-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 8/18/08, 10:01 PM
Carl Brown's Avatar
Ron,
Do you have a couple pictures?
Have you had or done an IR scan?
Is it possible to change the grade a little?
As Barry said 2 tickets would be better!
Old 8/18/08, 10:16 PM
Carl Brown's Avatar
How thick is your stucco?
Has it been painted?
You might be able to snap a chalk line on the wall and use a 4" diamond cutting blade set it on a 45 degree angle and cut the stucco.
Kinda like a redneck weep.
Old 8/19/08, 5:51 PM
After thinking about it further, I am thinking of pouring a sidewalk but leaving enough space between it for moisture to drip out and for concrete expansion. What do you guys think? I also added a couple photos. By the way, the rock wall extends down another 2-3 feet on the opposite side. I am re doing the grade. I have taken out about 12 inches of sand (what a job with a shovel and wheel barrow). Stucco has not been painted. The trench should not undermine the slab, plus after I pour the sidewalks I will probably put gravel in between the sidewalk and the slab. The gap between sidewalk and slab will more than likely be about 2 inches just so if moisture gets through the stucco it has a way to get out. The stucco is about 3/4 inch thick. Just tired of seeing the wicking effects of water and I do not want to have to start repairing stucco or have some one else do it.
No IR scan, but did remodel the master bath which is on this wall, had all the drywall off and did not see any signs of moisture penetration on the sill plate.
Also, I have read that painting a ortland cement type stucco is OK, and then I have heard it is not OK as the stucco needs to breath. What are your feelings about painting a cementatious stucco with an elastomeric paint?
no-weep-screed-picture-001.jpg   no-weep-screed-picture-002.jpg   no-weep-screed-picture-003.jpg
Old 8/19/08, 7:52 PM
Carl Brown's Avatar
As for the painting.
With the stucco having the color in it the longer you can live with the stains from the ageing the better off you are, once you paint stucco it does cut way down on the breathabilty of it. And the paint can trap moisture.
What is going on around your windows?
Stucco right up to them?
Backer rod and sealant joint around them?
Looks like you have no expansion joint's/control joint's.
Old 8/19/08, 8:06 PM
Man, you have good eyes Carl!
Me, I have drugstore 1X powers all over the house, office, shop and vehicle. LOL
Larry Kage, CMI
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 8/20/08, 9:08 AM
No backer rod or sealant. Very typical of the way they put stucco on here. Can the stucco be removed and the backer rod installed and then an elastomeric sealant added?
Old 8/20/08, 9:39 AM
Carl Brown's Avatar
It can but you might do more harm than good. imo
Why are you wanting to paint your stucco?
Old 8/20/08, 2:54 PM
My wife wants it a lighter color. Plus there are cracks that need repaired and matching the existing stucco color would be very difficult.
Old 8/20/08, 2:56 PM
What about fog coating it? Isn't that like putting another finishing coat on top of the existing coat that is already there?
Old 8/20/08, 3:02 PM
Carl Brown's Avatar
Ok!
The BOSS said so.
With all that has been said here how about getting an IR inspection?
As per ASTM and AAMA your stucco and windows are improperly installed.
Backer rod and sealant joints.
No weepscreed.
No expansion/control joint's.
With that in mind your house should have moisture problems out the wazoo.
If you get an IR scan and you do not maybe ASTM and AAMA might be wrong about a few things.
If you get one now and in 3-5 years you have a moisture problem after you put elastomeric paint on it maybe it could help explain a few things.
Old 8/20/08, 3:04 PM
Carl Brown's Avatar
You might very well still see the patches and the stains thru the new finish coat.
Old 8/20/08, 4:02 PM
Carl Brown's Avatar
Ron,
check your private messages
Weep Screed gheller Exterior 11 6/27/08 11:15 PM
Weep Screed details jfunderburk Exterior 9 2/23/08 8:54 PM
Space between weep screed and foundation aglad Exterior 3 12/23/06 9:22 AM
Adequate weep screed? jonofrey Exterior 21 9/4/06 12:33 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
