Old 5/4/08, 10:21 AM
Steven R. Butts's Avatar
Steven R. Butts Steven R. Butts is offline
Default No weep vents
Has there ever been a masonry unit used for veneer walls that did not require weep vents that anyone is aware of? The house in question is 48 years old.
Steven R. Butts, CD, CHI, CWI, CWS
Home Select Inspections Inc.
Kingston On
613.483.4308
www.HomeSelectInspections.com
www.Inspectorpages.com/sbutts
Old 5/4/08, 10:51 AM
Banned
Default Re: No weep vents
Is it showing any problems??
Old 5/4/08, 11:03 AM
No it's not Brian, but if they are porous units shouldn't i be concerned with possible mold inside the wall?
Kingston On
613.483.4308
Old 5/4/08, 12:40 PM
Bob Elliott's Avatar
Weep holes were not required then.
It is fine.
What gets through may be evaporating through the masonry as it is porous.
Look at all the three layer brick built 100 years ago that has no problem.
I hate to think what the masons would have thought back, then if you mentioned a weep hole.
The last thing you would want to do is start drilling holes in a wall with no moisture barrier.
Steven here is a article at TIJ that actualy has some good disscusion http://www.inspectorsjournal.com/for...?TOPIC_ID=5924
Old 5/4/08, 2:06 PM
It is fine.
Good point about the moisture barrier. I will write it up as acceptable because of past performance.
Thanks for the link too......great info.
Steve
Kingston On
613.483.4308
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Brick house nbhi Exterior Inspections 28 2/17/08 3:22 PM
Vents in siding?? sfalvey Exterior Inspections 7 11/17/07 9:58 PM
To weep or not to weep! rgant Exterior Inspections 14 2/15/07 12:40 PM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 9:20 AM
