Old 9/8/11, 8:50 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default No window flashing
Comments/recommendations on lack of flashing at window/nailing fin. House built in 2006. Thanks in advance.
no-window-flashing-img_0007.jpg   no-window-flashing-img_0006.jpg   no-window-flashing-img_0005.jpg
Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/8/11, 8:54 AM
Default Re: No window flashing
You could recommend sealing exterior cracks/gaps to prevent water entry and damage...
Larry Kage, CMI
231 929 3525
Old 9/8/11, 8:59 AM
James H. Bushart's Avatar
Point out the absence of flashing, the likelihood of eventual moisture intrusion/damage and recommend that all affected windows be repaired/replaced, as required, by a qualified and competent contractor. Let the contractor who will be held accountable for his work recommend the remedy. You simply point out the defect.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 9/8/11, 9:43 AM
David A. Andersen's Avatar
Around here the contractors call them "self flashed windows" and don't need nothing (till they see the thermal image from inside).
Larry, around here adding caulk from the exterior often holds the water in, instead of preventing it from coming in!
Oops, missed a spot!
BPI# 5015804
Old 9/8/11, 10:02 AM
You're correct, David, and, although I didn't mention caulk, I could have been more specific regarding avoiding moisture pentration in walls.
Larry Kage, CMI
231 929 3525
Need help flashing top of replacement window on brick wall !!! Bill Featherstone Exterior Inspections 5 6/26/10 10:25 PM
Window header trim flashing jfrederick Exterior Inspections 0 6/24/10 8:29 AM
Window flashing -- lfoster Exterior Inspections 43 10/28/07 9:47 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
