Did a builder's warranty inspection in a ritzy area. 8,200 SF home built bt a Realtor acting as a GC (Through her son).
The roof had a power vent fan, a short (about 10') ridge vent (very complex roof) and, on the outside, 6 static roof vents. It turns out (after examination by a real good roofer friend of mine) that only one of the six roof vents had openings to the attic. Some guy just installed the roof vents but never bothered to actually cut through the roof deck to allow them to, like, actually vent! About half of the soffit vents had baffles, but the blown in (fiberglass) insulation was actually blown into the baffles. WHAT were they thinking? Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Pretty crazy Will.
I also run into vents (stationary) with the sheathing there. Sometimes when your in the attic after being on the roof you wonder if the mind could be slipping a little.....!........hmmmm..wasn't there stationary vents here? Makes you wonder how so many folks overlooked it before the final....unreal. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
I found the same thing last week, the sheathing was not cut for the vents, here are the results. Most soffit baffles were also smashed against the roof sheathing. The insulation had rust dots on it from the nail heads dripping with condensation.
Will, they just forgot that beat the crap out of the OSB with a hammer below the vents before they were done!
Does anyone know what is saw is any more? |
The buyer should think himself lucky at least the builder used a roof deck
www.wisemovehomeinspection.com Carl Pennick Lighthouse Point, FL 954-946 2737 407-928 8489 Florida Licensed Home Inspector #65 NACHI #04072098 ICC #5294144 Certified Master Inspector |
{Now I have seen everything} I have learned not to say that anymore.I'm sure something else will come along that will blow you away!!! 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
That is part of what makes this job so interesting. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
