Old 4/2/08, 4:54 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Question oh and why are these used?
I am seeing different ***** everyday... why would these vents be installed? they are located at the second floor framing levels and just below some of the window sills... 1940's dutch colonial...
i realize they are some type of vent... but why? what was the theory behind adding these buggers in? venting insulation?
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 4/2/08, 4:59 PM
David P. Valley's Avatar
Default Re: oh and why are these used?
Jeff,
It does appear to be a vent. I've never seen holes like that on siding. There's no need to ventilate insulation in walls.
Old 4/2/08, 5:04 PM
David,
i have no idea... i've racked my brain... maybe someone here has seen them before... we'll see...
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 4/2/08, 9:09 PM
They installed them after blowing in insulation to help vent the moisture in the wall cavity because back then a vapor barrier was not used...didn't work that well.
Larry Kage, CMI
231 929 3525
Old 4/2/08, 9:23 PM
Barry Adair's Avatar
large installation photo
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 4/2/08, 9:39 PM
Christopher Currins's Avatar
Exactly
Christopher Currins
Certified, Licensed
Old 4/2/08, 9:42 PM
Frank J. Carey Frank J. Carey is offline
I agree with Larry on this one. I have seen in many older homes(plank houses) in my area that tried to insulte have these vents. I am not sure how well they actually work b/c usually they are painted right over after a few years.
Frank
Carey Inspection Solutions, LLC
Wilkes-Barre/ Scranton PA
Nachi ID -> 08022204
Frank@careyinspectpa.com
www.careyinspectpa.com
www.frankcareyconstruction.com
Old 4/2/08, 11:22 PM
I have seen larger versions... but did not think they would be able to insultate through these... but makes sense to me.
thanks all.
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 4/3/08, 6:37 AM
Originally Posted by badair
Barry,
Who's the beautiful broad?
Old 4/3/08, 6:46 AM
Banned
Originally Posted by dvalley
Jeff,
This is a test!!!
In early research into condensation moisture in walls, it was thought that venting might be the solution. In some of the houses, venting increased the moisture in the walls (and some attics also)......why??
Old 4/3/08, 7:00 AM
Banned
They just didn't have the proper solid plastic plugs. These are "vents" for undereaves......but they are so small with not much "net free area" that cracks around soffit and fascia materials will give much more venting than the vents. As for using them with wall insulation.... in wind driven rain areas, they will let in more bulk moisture (rain) than they will ever allow out by evaporation.
I have seen (many times) 3" versions of this undereave vent used to try and vent a bathroom fan!! Firstly, if the fan has a 3" discharge outlet, it's too small and weak; that particular fan cannot push water downhill. Secondly, most residential ventilation that I see is at the lower end of the quality scale in equipment, design and installation.
Old 4/3/08, 7:02 AM
Banned
That's a good thing!
Old 4/3/08, 7:11 AM
cwhite2's Avatar
cwhite2 cwhite2 is offline
Please Note: cwhite2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Originally Posted by Brian A. MacNeish
This is a test!!!
Temperature differential between exterior dewpoint & interior = condensation
The venting increases the flow of moisture laden air into & thru the building & condensation builds.
Am I close?
Old 4/3/08, 7:15 AM
Raymond E. Wand Raymond E. Wand is offline
Banned for Violating Forum Rules
Please Note: Raymond E. Wand is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are you sure the house hasn't been insulated with UFFI?
