| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
I made a bad call on a tile roof vent stating that is wasn't aligned properly with the hole in the sheathing. I was given a installation bulletin today from the roofer that I'll share so others don't make the same call.
"The placement of the secondary vent covers one tile to the right or left of the primary vent is acceptable under any weather conditions. The air from the attic is expelled from the primary vent under the tile and will use both the surrounding tiles and secondary vent(cover) as exit routes". I hate it when they are right and I am wrong. |
Could you post a picture and the brochure? "Never underestimate the difficulty of changing false beliefs by facts." |
Common vents on newer construction. . . http://www.ohaginvent.com/
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Services & Additional Topics | 12 | 2/13/08 12:33 PM |
| Vents in siding?? | sfalvey | Exterior | 7 | 11/17/07 10:58 PM |
| Cracks Above and Below Foundation Vents | Skip Erwin | Structural | 5 | 10/23/07 5:27 PM |
| Gable Vents | mpedeferri | Structural | 11 | 1/25/06 2:59 AM |
