Old 3/31/07, 4:45 PM
Barry Adair's Avatar
Default Old timers just kicked in! HELP
What is this red outlined section of roof called?
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 3/31/07, 5:08 PM
Default Re: Old timers just kicked in! HELP
Hi. Barry;
To be honest with you, I don't know, all I know is that I would never have let myself build something like that to begin with.
I would imagine one would or could call it a cricket diverter, but I don't think that will help the rain rush on to the siding that is on tight to the roof and rain water infiltrateing under the low lying shingles on the cricket.
Good luck.
How did you call it if you don't mind my asking?
Marcel
Marc D. Shunk's Avatar
Banned
Cricket.
Old 3/31/07, 5:20 PM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Cricket or saddle.....I have heard both terms used.
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 3/31/07, 6:36 PM
Originally Posted by mcyr
Hi. Barry;
Good luck.
Marcel
If you didn't like that you won't like this and I'm working on my description as we speak. I'll be back! I think the Archie-me-tech or roof framer blew this install on both sides.
Thanks to everyone but cricket and saddle are not correct IMHO.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 3/31/07, 6:41 PM
Bruce A. King's Avatar
Integrated triangular shed POS roof
www.BAKingHomeInspections.com
704 301-3207
Old 3/31/07, 6:42 PM
Roy D. Cooke, Sr's Avatar
I would call it a roof wall and to make sure it is well flashed as they are prone to leak.
Not the best way to do construction .
Roy Cooke
Old 3/31/07, 6:46 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is online now
funnel
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 3/31/07, 6:50 PM
Keith Swift, PhD. Keith Swift, PhD. is offline
Barry, whenever run-off is not direct, and has to change directions to leave a roof, I describe it as a "design-flaw." Sometimes, design-flaws cannot be avoided, but I always inform my clients about them and warn them that they need to be kept clean and monitored.
InterNACHI Vice President, InterNACHI Editor-in-Chief, co-founder CalNACHI
Old 3/31/07, 7:06 PM
Here's what I came up with for now.
Atypical framing design flaw techniques may cause dam conditions and have the potential to drive water runoff under the flashings and shingles. These areas are potential impact points for moisture intrusion. I was unable to access both of these areas of the attic to fully investigate for previous or present moisture intrusion. Consult a roof framing contractor for remedies
Keep them coming I'd like to have numerous sources to rely upon and the humorous ones are getting closer to my thought processes
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 3/31/07, 9:08 PM
mthomas2 mthomas2 is offline
No special term I'm aware of.
FWIW if I were reporting that - assuming that no evidence of leaking was detected - I would do it as FYI or Watch List item and would say something like:
“At (location) the roof design directs water from higher portions of the roof onto a lower slope-area alongside a wall (see picture). This is a poor design as water running down the roof will be directed with considerable force against the wall, and will then run alongside the wall where it meets the roof.
Even under ideal conditions it is difficult to properly seal the point where a wall meets a roof against water leaks, and in my opinion due to the design of this roof there is substantially increased risk that water will enter the house at this location. If this happens water will damage building materials, possibly including structural portions of the building, the exterior siding, the materials beneath the shingles, interior finished surfaces such as ceilings and walls, and other areas. Substantial damage might occur before it was detected.
I inspected this area from inside and outside the house at (locations) for the presence of moisture or moisture-related damage. At the time of inspection I did not find evidence of excessive moisture or moisture related damage, however I was not able to completely inspect (locations) for inspection because (reasons), and if damage is present in these areas it could have gone undetected.
The cost of the changes needed to prevent such damage or repairing it if it occurred could be a substantial expense. I recommend that you carefully watch at (locations) for any evidence of such damage, and that any evidence of increased moisture in this area be immediately investigated. If you wish to determine the cost of modifying the roof and/or wall to lessen the likelihood of such damage, I recommend that you obtain a quote for proposed improvements to these areas from one or more licensed and insured contractors also holding a state roofer's license.”
The picture(s) would include arrows indicating where I expected water would flow on the roof, and a cross section of a typical roof-wall junction illustrating were I would expect water might penetrate, the latter clearly labeled as an *example* of how such a junction is often constructed. (Assuming that is, that I had not been able to determine how that was actually flashed.)
Verbally, I would be quite explicit about how poor a design that was, and that I felt it was likely going to be one of the first, if not the very first, place on the roof to start leaking, and that when it did it could do a whole lot of damage before detection.
.... just my .02 worth.
Old 3/31/07, 9:10 PM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
What a screwed up design! Somehow, I doubt that a reputable architect was involved in that.
You comment looks great, but I would edit it to read "flashing, shingles, and exterior wall cladding"
Old 3/31/07, 9:28 PM
Barry,
that second pick is the frosting on the cake.
Let us raindrops and snow take a dive into this valley, whoaaaaaaaaaaa, I'm going under that cut valley, O K I'm going under the siding, see you inside. ha. ha.
Nice Barry
Old 4/1/07, 12:06 PM
Scott A. Figert Scott A. Figert is offline
Low sloped roof diverter, high piont leak potential. Installed by amateur builder. Or is that immature builder?
Old 4/1/07, 1:09 PM
David C. Macy's Avatar
It looks like a roof valley that is poorly constructed and is improperly directed at the siding that wiil eventually leak if there is flashing problem.
A cricket or saddle is a small gable roof that is typically installed for chimneys that are over 30 inches wide.
Where's NACHI on this Website? lcapaul General Inspection Discussion 77 7/31/07 5:00 PM
Dear bugmenot: gromicko Canadian Inspectors 303 11/9/06 5:49 PM
