Old 3/17/09, 3:08 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Open ended gutters
Would you call these open ended gutters a defect?
Thanks! for your input.
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 3/17/09, 3:13 PM
Brian E. Kelly's Avatar
Default Re: Open ended gutters
no..
Old 3/17/09, 3:16 PM
Joe Funderburk, CMI's Avatar
No..
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/17/09, 3:24 PM
Jeffrey R. Jonas's Avatar
No... but I may make mention of them... noting the increased wear to the shingles where the water falls upon them.
Old 3/17/09, 3:25 PM
Bob Elliott's Avatar
Yes a defect because of no down spout.
If the upper roof has a downspout to the lower roof gutter as it should then the open is a defect .
Why is the gutter even there? (hmmmmm)
Old 3/17/09, 3:28 PM
Would you call it a defect if the gutter wasn't there?
Old 3/17/09, 4:50 PM
You are wearing out the middle section.
Also those stubs are aimed sideways which will push the tiles up.
Rains is meant to shed down those tiles and not travel from the side.
Been discussed many times.
Thick of the water pattern during a heavy rain and guess what will wear out.
Hold your control button and hit the plus sign to magnify.
You can see splits forming from the ends of tiles below the downspout stubs.
Old 3/17/09, 4:53 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
i would call it out... they are not doing much good that way at all... either install them with downspout or dont install at all...
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 3/17/09, 4:54 PM
Bob,
Not saying I disagree with your opinion, just curious if you would call it a defect if the section of gutter was not even there?
Jeff
Jeffrey R. Pope's Avatar
No. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/17/09, 4:58 PM
Originally Posted by jjonas View Post
Bob,
Jeff
Probably not but it is
and I can only suggest not having two streams of water aimed at @ causing stress on the tile.
Do you see the splits?
Old 3/17/09, 6:10 PM
ldapkus ldapkus is offline
If you don't divert the water flow away from roof to wall transitions, during heavy rains the water will flow over flashings and down interior walls.
open-ended-gutters-no-downspouts.jpg   open-ended-gutters-moisture-intrusion-over-roof-wall-flashing.jpg
Old 3/17/09, 6:12 PM
mivie's Avatar
mivie mivie is offline
Please Note: mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Control plus....COOL I need more old folk's tricks. No more squinting at the screen.
Old 3/18/09, 12:22 AM
Ed Fako's Avatar
Ed Fako Ed Fako is offline
Please Note: Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
Also, hit the Control Key and use your Mouse Scroll Button to Enlarge Or Shrink the entire screen.
I also just found out by accident, that the Shift Key and the Mouse Scroll Button will move you back and forth, like click back a page or forward to a page you just left.
Now to the gutter.
It is better that they left the open end away from the bottom of the valley, because so many gutter installers attempt to get it as snug as possible, which then causes a continuous flow of water under the adjoining shingles.
I would hope that the drop outlet in this particular case expells the majority of water, but I don't like how the water flow will be forced upwards at the butt ends of the shingles in it's path.
Also, the "A" Elbow that jutts out of that gutter should more preferable be a "B" Elbow, so that the water flowage is pointed down the slop of the roof instead of sideways at the side butt ends of the shingles.
I did not notice any cracking of shingles under a higher magnification, but I did notice some mechanical damage, which more than likely was done with some sheet metal or a knife. It could be the roofer from the original install with doing some cuts on top of the shingles, the sider doing the same thing with his angles cuts under the soffit, or the gutter installer scraping the roof surface.
Ed
Philidelphia Gutters dosborn Exterior Inspections 11 9/21/08 6:59 PM
Open Neutral & Open Hot fmagdefrau Electrical Inspections 12 9/18/08 6:04 PM
House with no gutters... gbrasseur Miscellaneous Discussion for Inspectors 6 11/3/06 8:33 PM
Open attic access from garage jveivia Interior Inspections 13 7/26/06 12:01 PM
