| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
Usually I'm used to seeing closed cut valleys but this one is unusual. Suggestions would be greatly appreciated.
Thanks in advance for your help Greg Liebig, Owner Sheboygan Wisconsin Home Inspector 4-Square Home Inspections, LLC Where Knowlege will put your Mind at Ease © Sheboygan, WI 53081 (920) 451-4646 www.4squarehi.com Follow Us on Facebook Follow Us on Linked-In |
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
ccurrins is a non-member guest and is in no way affiliated with InterNACHI or its members.
Owl Home Inspections Rick Maday Itasca, IL Home Inspector Serving all Chicago Suburbs Schaumburg Home Inspector Naperville Home Inspector Lake County Home Inspector
it take foresight and layout to properly weave and have shingles line up check this for further info http://www.stargroup.com/Residential...html~mainFrame badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good |
Hmmm...looking at the pic again, it seems to be architectural shigles rather than 3-tab. Could be an illusion too.
Greg's pic are "laminated shingles"! badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good |
Yes, thanks.
BTW, good to see you back here. Owl Home Inspections Rick Maday Itasca, IL Home Inspector Serving all Chicago Suburbs Schaumburg Home Inspector Naperville Home Inspector Lake County Home Inspector
Lapped roof valleys are always suseptible for leakage. Look and the picture, and imagine where the water drains. Water can flow down the right side, into the grooves/joints/slots of the other shingles. Suggest replace with metal drainage valleys.
eyes paid da gubment fer tha day off!
always good to see the OWL badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good |
Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Woven is fine if the shingles are softened in the sun before positioning, and when woven so they cross near the center. Some of those cover 2-3 courses on the opposite side. I do them often, but that is poorly done.
Cut valleys should be a heads up...the roofer took the fastest, easiest, cheapest way to install the roof. Did he take any other shortcuts?
Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Woven valley's such as this are typical......I do them myself however where he got off on is how he weaved them in.......as you go up the valley the intersecting of the shingles are off......almost 12 inches away from the valley itself...................this often happens when you have two different pitches and or the installer is not paying attention to detail.
Just curious, was there two different pitches going on? |
I've done both Gary.........woven valleys are just as good as metal valleys if not better. For an inspector to suggest an alternative method is exceeding SOP's. This method is fine.....its simply that the installer was not paying attention to the valley line. The only way these types of valleys leak is from 1.) stepping in them 2.) perpendicular shingle did not extend far enough past the valley and 3.) the installer nailed to close to the valley. |
Probably did not install the metal flashing underneath. Just a guess. T.Neyedli CHI(P) www.alphahomeinspections.ca BPCPA #47827 |
![]() A well woven valley is hardly noticeable. You're looking at it--then it dawns on you what you're looking at. Both my son, and son-in-law, are roofers and use this technique a lot. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
| Valley | dmacy | Exterior | 35 | 3/31/09 9:56 AM |
| According to the latest opinion polls... | jwilliams4 | Misc. Discussion | 0 | 10/18/08 10:50 PM |
| Porter Valley Software (InspectVue) has been sold. | gromicko | Hardware, Software & Publications | 28 | 8/8/08 11:43 PM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | General Inspection Discussion | 3 | 3/3/06 11:43 AM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | Misc. Discussion | 0 | 2/27/06 2:42 PM |
