I don't know the answer to this one.
My theory is that heat rising to the peak causes the upper deterioration and ice dams cause the lower deterioration, except I think the one building is an unheated garage. Still, it probably warms up inside from the sun. Does this happen in climates where ice dams arean't a problem? ...anybody? Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Find an InterNACHI certified Arkansas Home Inspector (and anywhere else in North America) |
One word................ventilation.
How was the sheathing underneath? Jeff |
I think you're probably right jeff, but why isn't it uniform? Why the damage near the bottom?
Vaulted ceilings and no rafter bay ventilation. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Actually it is uniform.......along the top and the bottom.
You apparently have gable vented louvers....which probably is trapping the heat along the eaves while at the same time stagnant air or no cross ventilation existing is causing the shingles near the top to deteriorate.....if not for the additional layer under the ridge caps I suspect they too would be deteriorated. Organic shingles also tend to blister more than your fiberglass shingles....taking into consideration there is venting problem (condensation etc) I am sure this also has contributed to their failure. Is it a true vault or are they scissor trusses? Also was that the east side of the house, how the the other side of the roof look? The roof looks likes it about 15 - 20 years old but then again its hard to tell sometimes. I just inspected a roof that had 3 tab shingles that have last over 30 years.....I was amazed at their condition. If not for the poor venting and numerous hail storms we have had the owner could have probably gotten another 5 years or more. Any pictures of the interior........including infrared on the ceiling? Jeff |
Steven C. Meyer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Organic shingles?? are they available in the safeway produce department???
1982. Vaulted ceiling- no ventilation, photo of roof peak below. Condensation not much of an issue with this place I don't think. Very dry here (except for the unusually foggy day of the inspection) Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Hmmm... seems to me the problem area is approx where the full logs are located, am I correct???
The plot thickens... Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
It's above the outside wall, which is why ice dams comes to mind.
