What is it?
One inch thich brick veneer failing all over this structure. The exterior walls are warping and cracking. It's almost like this stuff was buttered onto a substrate like stucco, then the joints mortared in. Anybody familiar with it? What's it called? John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
An ugly mess!!!! only in America!
http://www.z-brick.com/page5.html www.buildingcenter.org Quickly determine the date of manufacture, age or production of most HVAC and Water Heating equipment Last edited by jbowman; 10/12/06 at 5:50 PM.. |
If it is one inch thick that doesn't sound like Z brick but more like someone used brick pavers. Without the benefit of brick ties to help support the brick veneer the weight alone would be enough for premature failure. Couple that with poor mortar joints and adhesive it was pretty much doomed to fail. All it takes is a little wind driven water behind the brick (thru the failing mortar joints) to begin separating the veneer from the substructure. It looks like crap and it may be worse underneath.
It looks like a Harry Homeowner job to me. I've never seen that either J.O.
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
www.buildingcenter.org Quickly determine the date of manufacture, age or production of most HVAC and Water Heating equipment |
More research on thin brick Manufacturers found;
Thin brick was popular in Maine in the early 70's and in the later, started to be used on the exterior for some veneers. http://www.thomasnet.com/products/th...6094578-1.html Hope this helps. Marcel |
| Home Inspector Listings | jbowman | Miscellaneous Discussion for Inspectors | 230 | 3/21/12 9:35 PM |
| Is this for real? | hgordon | IAC2 Indoor Air Forum | 47 | 10/30/06 9:31 PM |
