Are the joist hangars to supposed to be the same size as the joists?
Is there a 2% slope rule for this? Any other issues. The buyer said he heard from another inspector that this was wrong on another home he had bought in the past. I told him I would look into it. Thanks. Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
| Find an InterNACHI certified South Dakota Home Inspector (and anywhere else in North America) |
Joist hangers should be the same size as the joists.
Those are undersized. |
2% slope for what?
No live loads. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
I suspect it is fine. See the attached Tamlyn chart, i.e. a 2x8 and a 2x10 can use a 7" hanger. Did you measure the joists and the hangers?
I'd be more concerned with the albino support column that was added to stop the deflection of the main carrying beam.
Could you ask them to jack it up another inch or two? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
dbolduc is a non-member guest and is in no way affiliated with InterNACHI or its members.
The carrying stick needs more than jacking, take another look.
can't tell what the partial covering is but most decent drainage basic rule of thumb is calculated at 1/4" per foot or grater even for flat roofing materials
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
It's a sun screen not a roof. It isn't meant to shed water so don't know if the 2% slope is as important.
What else are you suggesting?
| Patio Cover, Make up your mind | bkelly2 | Structural Inspections | 23 | 3/7/09 11:45 AM |
| Electric Panel | dmozzillo | Electrical Inspections | 26 | 1/26/09 2:18 PM |
| Fireplace Vent and Patio Cover Framing Clearance? | rwashington | Exterior Inspections | 6 | 6/10/08 10:54 PM |
| strange hole under patio | cwillick1 | General Inspection Discussion | 14 | 4/9/07 11:50 AM |
