tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
This patio roof was installed over the top of the shingles...which I thought was odd...now I'm wondering how the heck the re-roofed it without removing the patio.....see what I mean?
I don't like the flashing...anyone else care to chime in? |
jwisecup is a non-member guest and is in no way affiliated with InterNACHI or its members.
neumann, where do you find em? Are you sure this realtor is a friend of yours?
Was the top side of this roof done right? ( I suspect I already know the answer to that) If it was then it wouldn't matter as much, right? |
The patio cover looks like an after market add on to me.
Tony, were you at the same house as me yesterday?
Tony,
the construction and framing of that additional roof are obviously well below std, what are the rafters attached to, the sheathing? I would be calling for a much more detailed evaluation of the porch addition. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
It looks like that is going thru the roof, is it attached in the attic ?
If the roof is installed over the patio and roof and covering this area, it would not be considered flashing for water. Do you have a picture from above of this transition?
If that was added on and then shingled over, it all depends on the shingle transition on top, might be fine , though I would look deeper at how the patio itself was attached
"If God was one of us, would he recommend a detailed analysis by a structural engineer for the world?" Michael S. Saxton http://www.duluthhomeinspections.com |
I would ditto Michael's post.
I find similar stuff as that in the picture quite often in some of my lower-end neighborhoods. That type of installation does save money and I haven't detected any specific problems with it when it is done well. NACHI 2005 U.S. Member of the Year
A Frame house covered w/ 1 foot of snow....this side of the house was on the "shade" side....that roof was 1 foot of snow covering 3 inches of ice....I took one step and changed my chicken mind! I wanted to see that transition as well, but alas, I could not. So I made note of it....and told him to check it out....I also mentioned that there were zero signs of problems in the soffit area underneath this area...and the shingles and roof sheathing looked good as near as I could tell.....but it looked "unorthodox" and he should give it a good looking at come summer....you know from August 3rd - August 8th every year
Was it attached in the attic?
No attic.....AFRAME...this was a great clean inspection....no attics, no crawls...no GARAGE DOOR OPENERS!!!
I couldn't see through the soffit, I am guessing (ooops) that it was attached to the trusses/rafters....but I cannot be sure. |
Ben...Please read the quote you quoted.....I will not remove flashing.....I will not die on a roof.....
I am like you...I want to find out EVERYTHING...but sometimes I cannot and it does bother me....but what can we do? Snow and Ice are things I have to deal with. Until they come out with nice XRAY glasses that really do work, I will have to just have some unanswered questions.....sigh. By The Way...how did the little winkie icon get put in for this thread? I don't put them on.....who does? TY>.. Last edited by tneumann; 3/24/06 at 9:33 AM.. |
I was speaking of the "flashing" on the under sidewhere there was no snow. I haven't seen any xray glasses on the market either. I was just wondering. starting out it is worth being the one who goes the extra mile. Seeing if the patio was attached to the rafters woud have decided much on this picture. (it appears)
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
| Questionable wall to roof flashing | dbucknavich | Exterior Inspections | 4 | 8/14/06 1:57 PM |
| Roof Flashing | psmothers | Exterior Inspections | 24 | 1/28/06 11:23 AM |
