Old 12/2/06, 11:35 AM
kweiss's Avatar
kweiss kweiss is offline
Default What is this pipe for?
Have seen this before and never been able to figure out what it is. Don't see it all the time, but occasionally. It is a small plastic, presumably pvc, pipe sticking out of an exterior wall. It is NOt the water heater pan drain, TPR drain, A/C condensate drain. It was located on a dining room wall. Closest plumbing type stuff was probably 20' away further to the left in the picture.
What the heck is it?
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 12/2/06, 4:21 PM
bsumpter bsumpter is offline
Default Re: What is this pipe for?
Is there a fire control sprinkler system installed?
Brian R. Sumpter
First Call Inspections
Proudly serving most Bay Area Counties
www.firstcallinspections.com
Old 12/2/06, 4:34 PM
rwand1 rwand1 is offline
Water conditioner discharge, sump pump discharge, air intake for furnane, high efficency water heater discharge/vent
Old 12/2/06, 4:45 PM
kweiss's Avatar
Would have to say no to all of the guesses so far. Slab foundation, no sump pump, typical for this area gas furnace in attic, typical gas water heater in garage on other side of house.
Keep the info coming!
Kevin Weiss
Level I Infrared
972-463-0887
Old 12/2/06, 4:58 PM
Kevin
Considering the location above ground and size of copper fitting (appears to be 3/4"-1" elbow), I'm gonna guess it is the discharge line off the TPR valve of the Water Heater.
Did you see a location for TPR discharge on other side of house for WH. Our code requires it go to the outside.
Old 12/2/06, 5:14 PM
Kevin
I went back to your 1st post. I missed the reference to Plastic/PVC. If this is a two story home and laundry room is on the 2nd floor, look for aux. drain pan under the washing machine.
Old 12/2/06, 5:48 PM
kweiss's Avatar
Originally Posted by gveal
Kevin
BINGO!!! I think you are right. This home had the laundry room upstairs (realtively rare around here) with a pan under the washer. Thinking back, I believe the other places I have seen this had an upstairs laundry room as well.
Thanks Greg!
Kevin Weiss
Level I Infrared
972-463-0887
Old 12/2/06, 6:59 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Drink a six pack, pee in the drain pan under the washing machine, see if anything comes out the pipe.
See those a lot here where the laundry is on the second floor. Though I occasionally see the laundry on the second floor without an exterior drain for the pan or sometimes even NO pan.
Code & common sense typically require an exterior drain for all laundry rooms located on the second floor.
Old 12/2/06, 8:03 PM
Jeffrey R. Pope's Avatar
Nevermind the pipe. What's that white stuff all over the ground?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/2/06, 8:10 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Jeff
We received the same amount here in Toronto this morning[first time this year] and it was gone by the afternoon.
I think it's called "White Mold"
</IMG></IMG>
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 12/2/06, 8:27 PM
I would have to retire, and lock all the doors. I don't do cold. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/2/06, 8:59 PM
Mouse access pipe.
Old 12/3/06, 12:15 AM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Erby - Where in the code does it say you have to have a drain pan on the second floor.? The only place I found this was manufacturer recommendation and not in the code.
Old 12/3/06, 9:31 AM
Russel Ray's Avatar
Where did you find margarita six packs?
Here in my area those pipes are, indeed, from the floor drain in the laundry room on the second floor.
Old 12/3/06, 9:33 AM
Russel Ray's Avatar
Well if "mold is gold," then "white mold is..." Silver? Platinum? Cocaine? Sugar?
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Vent pipe dlee2 Plumbing Inspections 4 9/17/07 11:28 PM
