Ok I have a leaking basement. House was built in 2006 new and never lived in. I figured the basement was leaking due to the fact that all the water from the back of the roof was poring on the right side of the house (thats were the leak is). My client is asking me about some plastic that was left on the house. It comes from the seal-plate and goes down in the ground about 3ft along the back side of the house. The black sealant is also in place. Any thought about the plastic?
| Need a home inspection in Louisiana? Check out InterNACHI's listing of Louisiana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is it PWF construction?
Have any pictures? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
No pics, i was thinking the plastic was from the curing process and just never removed. however i just came back from the house tonight and they were removing all of the insulation and its all wet so theres more problems then the first inspection revealed.
The plastic could be a water barrier not a damp proof ,but should be around the total perimeter of the homes foundation.It will go from grade to footing.Very thin clear plastic with black tar behind it that was sprayed onto foundation walls. plastic on top to act as shield to prevent tar from drying out and appears black from tar behind it.
If its a brick or stone vainer- a thick black plastics is placed upon the foundations top to accept the bedding for the first course of brick or stone to act as a gasket so martor will not stick to foundation.Some times it comes in a roll 3 feet wide 100 feet long and drapes over the foundation as to protect anything below it from getting masonary on what ever is behind or under the work in progress,windows, ledger boards, angle iron etc.. In some cases I have seen it left intact after the work has been completed,for it should be cut away after work has been completed .It is left draped over the foundation from the sill-plate {it is not to be placed upon sill-plate but sometimes is} down 3 feet,the width of the plastic.The foundation guys are running late putting in French drains,or the back yard has not been graded yet for the home is built on land that slopes and the void is filled after the brick work had been completed leaving the plastic barrier bumped up against the foundation wall.Not good build practice. As I mentioned pictures are a great help for the situations are endless. Last edited by ryoung7; 5/14/10 at 4:46 AM.. |
| Poly being applied to Basement walls | dvalley | Interior Inspections | 40 | 11/24/09 10:49 PM |
| Basement vapor barrier | jfrederick | Interior Inspections | 10 | 2/14/09 4:54 PM |
| Basement Floor Mystery | aberdahl | Structural Inspections | 6 | 10/23/08 5:22 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Basement Work Done In Past | Nick Scibetta | Structural Inspections | 18 | 10/31/06 4:21 PM |
