Old 4/1/10, 8:10 AM
John Evans John Evans is offline
Default Plywood Gussets
Modular home built 1971. Roof structure appears to be site built trusses. Any opinions on the use of plywood gussset plates?
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/1/10, 8:19 AM
Joe Funderburk, CMI's Avatar
Default Re: Plywood Gussets
It will be interesting to hear what others say. You have to consider that it's been OK for nearly 40 years. Everything looked plumb and at least their system was consistent at each truss.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/1/10, 8:35 AM
Wayne B. Wilson's Avatar
I agree Joe it has worked for this long, And if it was a modular it should have been approved at one time.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 4/1/10, 8:39 AM
It is typical manufactured home construction and, unless there is evidence to the contrary, it appears adequate.
Larry Kage, CMI
231 929 3525
Old 4/1/10, 9:29 PM
Larry J. Michael Larry J. Michael is offline
Typical here also
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Old 4/1/10, 9:37 PM
Marcel Gratton's Avatar
· Further Evaluate: The roofs trusses are homemade meaning these were not designed by an engineering firm consequently do not come with any guarantees of performance. We recommend that you consult with a structural engineer to confirm their integrity.
On The Level Inspection
Gatineau, Québec
Old 4/1/10, 9:49 PM
ldapkus ldapkus is offline
They didn't consult an engineer 40 years ago. Why now???
Old 4/1/10, 10:12 PM
Christopher Currins's Avatar
What would you say about the roof truss construction of this modular; built in 1980, that I inspected last week?
Christopher Currins
Certified, Licensed
Old 4/2/10, 1:15 AM
Originally Posted by ccurrins View Post
what would you say about the roof truss construction of this modular; built in 1980, that i inspected last week?
is this a trick question?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 4/2/10, 2:27 AM
No.... at least I hope not.
Christopher Currins
Certified, Licensed
Old 4/2/10, 2:27 PM
Same!
Keep in mind that where I am there is snow load to consider and I've reported on many homemade trusses with wood gussets that failed. I also see engineered trusses on 1960 homes where the metal gussets are separating / loose.
I don't know if it snow's where John is but it did in a lot of areas where it usually doesn't this past winter...
Gatineau, Québec
Old 4/2/10, 4:02 PM
  • The plywood gussets typically mean non-engineered trusses. Recommend SI
  • The 2x6 bracing under each of the ridges was not built by someone familiar with standard building practices. Poor quality work
  • A combustion vent terminates in the attic
(303) 717-8940
Old 4/3/10, 1:02 AM
In addition to Ken's comments no H-Clips, poor attic ventilation not to mention insulation...
Gatineau, Québec
Old 4/3/10, 3:53 AM
H-clips probably weren't required when this was built, Marcel.
In CA, we never had to install any until about 1985, and even then that was an architects call. They're still not required in a number of areas.
(303) 717-8940
Old 4/3/10, 7:01 AM
David P. Valley's Avatar
Attachment 36146
Attachment 36147
Attachment 36148
I've seen this type of truss connection several times in the older homes. They're fine.
New article on the pros and cons of OSB and Plywood inxil InterNACHI & RealMatcher Blogs 0 10/6/09 3:30 PM
FRP Plywood mschniers Structural Inspections 3 2/2/08 5:27 PM
Treated Plywood ? Homey Structural Inspections 4 3/23/07 2:10 AM
3/8" plywood roof sheathing kshepard Exterior Inspections 12 8/15/06 7:28 PM
