I have been called about a pre-listing insp. They have informed me they have a pond roof (The roof is 2x12 8"o.c. and holds 4" of water at all times with a float and water source). Has anyone heard of them or know where I can get some info?????????
Have never seen one and most of what I have read is usually a little strange and sone ones Ideas. I do not think I would build one but willing to learn. http://www.pondroofing.com/about_us/ http://livemodern.com/forums/offthegrid/971184826 http://wordpress.com/tag/roof-pond/ Would love to hear how you make out. .........Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
I believe that an IRMA roof, Inverted Roof Membrane Assembly, was intentionally designed to hold water rather than to shed water.
There was a discussion on JLConline dot com about two months ago about a similar topic. I looked up Inverted Roof Membrane and found this pdf file so here is the link if you think it will help you. http://www.buildingenvelopeforum.com/pdf/flatroof.pdf Ed |
IRMA roofs simply have the insulation applied outside of (above) the roofing membrane rather than under it. They are never intended to retain water. The reason for the inverted construction is to protect the roofing from UV rays and to also protect it against major temperature variations.
You guys are bringing back old memories about what I always called the upsidedown roof system. BUR.
Steel deck on the structural steel and then a 5/8" gypsum board applied to mop down a 3-5 ply system and then a complete mop over the whole membrane. Then the insulation was applied and held down with 10# of stone ballast. This was usually river washed stone that was available at the time. That was banned in the late 70's, for the impact enviroment it created on the rivers. Wicked poor system. Saw it installed in the early 70's and never again. Any leak in the system was impossible to find and the steel structure had to be designed to hold that ballast system. Never seen it again in this area. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I knew I remembered reading about this type of roof before over at the JLConline.com/forums
website. http://forums.jlconline.com/forums/s...ad.php?t=36694 Ed |
The Building Envelope Forum that you found is a free e-zine run by a retired building scientist, Jacques Rousseau, formerly of Canada Housing and Mortgage Corp. It comes out 4 times per year and has some of the best Canadian building scientists, architects, etc contributing. Would definitely interest you but note that some like Rick Quirouette (a lifetime building scientist) think like me about roofing moisture problems. The archives are found here: http://www.buildingenvelopeforum.com/archives.htm You'll have to read this one- "The Anatomy of an Ice Dam": http://www.buildingenvelopeforum.com...0for%20web.pdf Brian Last edited by Brian A. MacNeish; 8/11/07 at 11:40 PM.. |
A paper about a study regarding pond roofs from 1984 or so.
Ed http://www.ceen.unomaha.edu/solar/documents/SOL_17.pdf |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/23/09 11:52 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
