| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
Concrete porch was level. Moisture staining inside at baseboards/floor. No type of flashing where the vinyl siding meets the concrete, and minor dryrot/moisture damage when poked with screwdriver from the exterior. Now, what would be the proper way to flash/seal this?? I understand decking with a ledger board, but what do you do with concrete, as in this case ???
Thanks again!! |
| Find an InterNACHI certified Michigan Home Inspector (and anywhere else in North America) |
No one is going to be happy with that leakage.
A step down is appropriate with the concrete graded away. Remove the stoop and do it right. That's what I'd recommend. ____________________________________________ "An Education, not just an Inspection" Larry Kage Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond. ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Larry, it must be help night, I was getting the info while you posted.
I would recommend this. http://www.jamsill.com/ Plus the landing should have been 1" lower than the bottom of the sill and proper flashing behind the pan. Like Larry said, remove the stinking thing and do it right. At the very least, they could of used sealant to prevent the water intrusion under the sill. Water intrusion is also happening behind the siding and rotting out the wall sheathing. Report; Water intrusion from the door sill evident and needs repair by a Quallified Building Contractor. Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
You guys rock, thanks a million.
Whatever happened to watching Friday night high school football games??????? ...... Damn, I think I should have been an Accountant. |
Think what the wall studs must look like.
Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 2:30 PM |
| Post tension slab labeling | rchorey | Structural | 34 | 7/7/08 12:43 AM |
| Moisture in slabs | mcyr | Structural | 7 | 8/20/07 8:33 PM |
| bbbb | mcyr | Structural | 1 | 8/19/07 11:26 PM |
| Moisture control for slab on grade in protecting floor finishes | mcyr | General Inspection Discussion | 2 | 8/13/07 8:53 PM |
