jimhanson is a non-member guest and is in no way affiliated with InterNACHI or its members.
hi guys,
I am not a home inspector. I am just trying to figure out how to walk on my red tile roof without breaking any tiles. I have walked my own and I have already broken a tile. Do you put your foot across the ridge of 2 tiles ? Do you put your foot just along the ridge of 1 tiles ? Do you put your foot diagonally across 1 tile ? Do you put your foot diagonally across 2 tiles ? Do you put your foot in the valley between 2 tiles ? thanks, Jim |
As a home inspector I'm not required to walk roofs as per NACHI standards. When I come across tile roof I don't get on instead I use my binoculars from the ground and at the eaves. You should do the same. This will save you a whole lot of trouble.
Clay tile is almost impossible to walk without damaging/breaking tiles (unless you weigh less than 100 lbs.), however, if you must walk the roof, the best method is as in picture #1.
Also, you need to step where the tiles "lap" eachother (toward the lower edge of the tile). This way, you're actually standing on 4 tiles with one foot. Hopefully you have some spare tiles. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 1/10/06 at 6:28 PM.. |
Sorry, but I have to say this... Rent a boom truck.
The only way not to brake tiles is to not touch them. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
I never walk tile roofs .
Roy sr |
I agree with Jason, rent a boom truck.
Why the hell would you want to walk on them anyway? |
NWJon is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with Jeff Pope. A 26 year veteran of building customs and I have learned a variety of ways to make and do things that seem not do-able. Ideally... don't walk on a clay roof... but if you have too... Jeff's description is correct... Also, another method is to distribute your weight to 3 or 4 points (still on the lower edge of the tiles) using your hands. You would be basically Crab walking. (hard on back, I know from experience) Anyway... good luck.
Cheers, Jon |
Contact a professional roofer to do the job, that way, he will be better equipped to do the job right!!!!! |
thanks guys.
i walk my red tile roof to put up ham radio antennas. so , i just wanted to find the best way. thanks, jim |
jcundiff is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would use a hook ladder and stay on the ladder. If its a lower pitch, maybe plywood- just make sure the plywood stays put.
SunReal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Clay tiles should never be walked on period. I walk on concrete tiles roofs as often as I can get on them safely. They are designed to be walked on, if installed properly. In my opinon the only way to really inspect a roof properly is to walk on the roof and view all areas.
Its a matter of ethics for me and my company. If I break a tile (have yet to during an inspection...have broken several on my own roof, while doing maintenance and when I installed a skylight)...anyway I have a corporate policy that states we identify if we break a tile during the inspection (or anything else) and have a policy about how we compensate for the damage. Maybe somebody can convince me that they can inspect a roof at the same level of detail that I can while on it, without being on it, but I dont know how . |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| reason to walk the roof | psiposs | Exterior Inspections | 64 | 5/14/07 12:55 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
