Old 11/24/06, 5:18 PM
gbrasseur's Avatar
gbrasseur gbrasseur is offline
Please Note: gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Question on entry door......
Hi Gang,
Don't entry doors going into the house from the garage have to be on a spring loaded hinge??? Or does this differ from state to state?
I was under the assumption it was required.
Old 11/24/06, 5:22 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Default Re: Question on entry door......
I have never seen one like that here. I like to have the door open when the bay door is open, like for parties, etc.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 11/24/06, 5:24 PM
Barry Adair's Avatar
This is up to AHJ.
I believe this has been removed from IRC.
Not seeing them on new construction.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 11/24/06, 5:39 PM
Roy D. Cooke, Sr's Avatar
Originally Posted by gbrasseur
Hi Gang,
Required in Ontario on all homes .
It is a saftery hazard .
We have had people over come from car fumes with car running in Garage. Doors also must be gasketed.
Roy Cooke
Old 11/24/06, 5:43 PM
bsumpter bsumpter is offline
Required in my area as well.
Brian R. Sumpter
First Call Inspections
Proudly serving most Bay Area Counties
www.firstcallinspections.com
Old 11/24/06, 6:01 PM
mlopezi mlopezi is offline
Please Note: mlopezi is a non-member guest and is in no way affiliated with InterNACHI or its members.
required here also
Old 11/24/06, 7:41 PM
tdietrich1's Avatar
Not seen here in Pa.
I guess in Pa, if you run your car in your garage, leave your door open, and go inside for a nap, it's just filtering the gene pool.
But seriously, I've been hearing of problems with people with a handicap being injured by these doors. The two handed operation of holding open a door, and holding a railing while walking up a few stairs can be a challenge to some.
tom
Old 11/24/06, 7:58 PM
Jeffrey R. Pope's Avatar
Self-closing devices are required by the UBC, not by the IRC.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/24/06, 8:31 PM
gbrasseur's Avatar
Jeff, forgive me for being naive, does UBC stand fro Uniform Building Code? Whats IRC. And, if UBC does stand for that, I guess it is no question to call this item out? This is a brand new house. Thanks
Old 11/24/06, 9:07 PM
Dale Duffy's Avatar
Greg, I just looked at Colorado Springs Building Codes, they seem to follow the Uniform Building Code, which requires self-closing hinges.
Unless of course the AHJ made a change (which certainly happens).
Old 11/24/06, 9:12 PM
International
Residential
Code
Old 11/24/06, 9:35 PM
Just to reiterate - the Uniform Building Code (UBC), Section 302.4 requires the door to be self-closing. Colorado follows the UBC, so it's a safe bet, that this is a requirement (rather than calling it a "requirement," recommend that one be installed).
The International Residential Code (IRC) no longer requires this. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 11/24/06, 9:48 PM
We in Canada are do not use code But I do call them out as a safety concern and recommend Immediate repair
Roy Cooke
Old 11/24/06, 10:58 PM
Greg
No requirements in my state for Residential Housing, unless the Housing carries a handicap (ADA) designation of usage. The obvious framing, seals, gasketing, thresholds are required, but have never seen auto closures on a Garage Door to Living Space, other than Owner add-on.
Old 11/25/06, 12:54 AM
gbrasseur's Avatar
Thank you to all of you who took the time to answer this post! I appreciate those of you who answer with your well thought out replies.
Regards,
Bad Door and Water on the Floor jnicholson Exterior Inspections 7 10/4/06 10:45 PM
I damaged my second garage door today mmorgan Exterior Inspections 47 3/9/06 8:14 PM
Door question jmichalski Interior Inspections 16 1/11/06 11:00 PM
