Old 5/26/07, 2:23 PM
Mark R. Long's Avatar
Mark R. Long Mark R. Long is offline
Default Question about exposed styrofoam insulation.
Is it acceptable to have exposed styrofoam board in an attic, or any other place for that matter? I'm thinking that this needs to be covered, but I'm having trouble finding a good definitive statement. Anyone have any good info or links?
thanks,
mark
Mark
MD HI Lic # 30090
BPI Certified Building Analyst
PA DEP Radon Cert # 2457
Certified Home Energy Tune-uP Inspector
Old 5/26/07, 3:04 PM
Ed Fako's Avatar
Ed Fako Ed Fako is offline
Please Note: Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Question about exposed styrofoam insulation.
As an insulation product on TOP of the roof deck, in some flat roofing asssemblies we have done in the past, it was required to be sandwiched in between two layers of fire-retardent fiber-board insulation/recovery board because of the flammability, quick flame spread and poisonous gas emmissions if it were to catch on fire.
Thats not your specific answer, but at least a gudeline to have an understanding about the products hazards.
Ed
Old 5/26/07, 4:50 PM
thanks,
mark
This may help.
Look at last paragraph
Foam and Foam Board Insulation
Even though many foam insulation products are more expensive than other types of insulating materials, such as fiberglass, cellulose, etc., they are commonly used in buildings where there are space limitations or where very high R-values are desirable. Foam insulation R-values range from R-4 to R-8 per inch of thickness (2.54 cm), which is 2 to 3 times greater than most other insulating materials of the same thickness. Also, if the installation is carefully installed, foam insulation may control air infiltration more effectively than other types of insulation.
Several variables affect the installed R-value of foam insulation, including: the initial density of the foam; the blowing gas used (CFC, HCFC, CO2, air, or a number of other gases); how the foam insulation is handled (dents and chips adversely effect the R-value); the type of facing (if any) used; and the conditions in which the foam is installed.
Foam insulation is often made with one of three materials: molded expanded polystyrene (MEPS), extruded expanded polystyrene (XEPS) or polyurethane, polyisocyanurate, or a related chemical mixture. Some are installed as a liquid while other types come as factory made panels or "foam board."
Liquid Foams:
Liquid foam insulation can be applied from small spray containers as a liquid or in larger quantities as a pressure sprayed (foamed-in-place) product. Both types expand and harden as the chemical mixture cures. It also conforms to the shape of the cavity to fill and seal it thoroughly. This type is often used in new construction.
There are also slow curing liquid foams that are designed to flow over obstructions before it expands and cures. This type is often used for empty wall cavities in existing buildings. There are also liquid foam materials that are poured from a container.
Both are generally urethane foams. Latex and organic based foams are available too. Be aware that these alternatives do not have as high an R-value as a urethane-based products.
Molded Expanded Polystyrene (MEPS) Foam Board:
MEPS is a closed-cell material that can be molded into many everyday items, such as coffee cups and shipping materials, or into large sheets as construction insulation. This material is commonly known as "beadboard," and it has an R-value of about 4 per inch of thickness [2.54 cm].
To make beadboard, loose, unexpanded polystyrene beads containing liquid pentane are mixed with a blowing agent and poured into an enclosed container. The mixture is then heated to expand the beads many times their original size. The beads are then injected into a mold and under more heat and pressure expand to become foam blocks that are then shaped as required.
The physical properties of MEPS vary with the type of bead used, but the density of the board is usually one pound per cubic foot (16.3 kilograms per cubic meter.) Beadboard is manufactured at various densities, depending on the application. Beadboard for roofing materials has to be dense enough to walk on without damage. Wall insulation boards are several times less dense than roof boards. R-values range from 3.8 to 4.4 per inch (2.54 cm) of thickness. Since spaces between the foam beads can absorb water, a vapor diffusion retarder is necessary if water transmission through the insulation might present a problem for the user.
MEPS foams are also available as small beads of foam too. This type is often used as a pouring insulation for concrete blocks or other hollow wall cavities. However, be aware that poured beads are extremely light-weight and take a static electric charge very easily. They are notoriously difficult to control and any wind at all often results in the beads flying all over the place. Also, if there is ever a hole in the wall the foam beads will continue to fall out of the hole until the wall is almost empty of beads.
Extruded Expanded Polystyrene (XEPS) Foam Board:
Extruded expanded polystyrene (XEPS) is a closed-cell foam insulation similar to MEPS. To make it, the polystyrene pellets are mixed with various chemicals to liquefy them. A blowing agent is then injected into the mixture, forming gas bubbles. The foaming, thick liquid is then forced through a shaping die. When cooled, the panel is cut as required. Foam densities are typically 1.5 pounds per cubic foot (0.21 kilograms per cubic meter).
XEPS is more expensive than MEPS, and like MEPS the R-value depends upon the density of the material. Generally, it's about R-5 per inch. It is also much more consistent in density and has a higher compressive strength than MEPS, making it better suited for use on roofs or for wall panels. Extruded polystyrene also has excellent resistance to moisture absorption.
Both MEPS an XEPS are often used as the insulation for Structural Insulating Panels (SIPs) and as Insulating Concrete Forms (ICFs.)
Polyurethane and Polyisocyanurate:
Polyurethane and polyisocyanurate are both closed-cell foams that contain a low-conductivity gas in the cells (usually one of the HCFC or CFC gases.) The high thermal resistance of the gas gives these foams an R-value of between R-7 and R-8 per inch.
Both types are available as a liquid spray, poured foam and also as rigid boards. They can also be made into laminated panels with a variety of facings. Foamed-in-place applications are usually cheaper than installing foam boards and perform better since it molds itself to all of the surfaces perfectly. However, be sure you use a contractor with plenty of experience with spray foam installations.
Over time, the R-value of the foam drops as some of the gas escapes and air replaces it. This phenomenon is known as thermal drift. When manufactured, the initial R-value is roughly R-9 per inch. Experimental data on this type of foam indicates that most thermal drift occurs within the first two years after manufacture and slowly decreases until it stabilizes at about R-7 per inch. It then remains unchanged unless the foam is damaged.
Foil and plastic facings on these foam panels help to slow the escape of gas from the cell structure. Testing suggests that the stabilized R-value of rigid foam with metal foil facings remains unchanged after 10 years. The reflective foil, if installed correctly, can also act as a radiant barrier (another type of insulation) that adds about R-2 to the insulating assembly. Panels with foil facings have stabilized R-values of 7.1 to 8.7 per inch.
Common Applications of Foam Insulation:
Spray foam and foam boards can be used to insulate almost anything, including: roofs, walls, foundations, entry and overhead garage doors, pipes and tanks, under basement slabs, or over a slab-on-grade floor. Foam insulation sprayed or placed in wall and floor cavities both insulates and offers some degree of soundproofing.
Protect all types of foam insulation from direct sunlight. Over time, the sun's ultraviolet rays can damage them. For roofs this is generally done by applying a coating such as tar, acrylic, silicone or rubberized paint. You can also cover the foam with a rubber or plastic membrane or a layer of asphalt and roofing felt. Make certain you are using compatible products. The solvents in some coatings dissolve certain plastics.
There are several ways to incorporate foam insulation in concrete or masonry walls: pouring loose foam beads into masonry blocks; injecting/ pouring liquid foam into the hollow block cores; manufacturing concrete blocks to accommodate rigid foam inserts; as lightweight concrete blocks that have polystyrene beads in the concrete mixture; and as rigid foam insulation inside a cast-in-place wall. There are also interlocking rigid foam panels and blocks that serve as permanent forms for concrete walls and foundations. These are commonly known as Insulating Concrete Forms (ICF's.)
Potential Moisture Problems:
In cold weather, warm inside air containing water vapor can get past the wall finish and insulation and condense inside the colder wall cavity. In hot-humid climates the same thing can happen, just in the reverse direction, humid outdoor air in the summer can condense inside cool/air conditioned wall cavities. If enough of this happens, and the water cannot escape, wood rot, mold, and other moisture-related problems are likely to occur. For this reason, building codes often require installing a vapor diffusion retarder on the warmest side of the wall cavity.
Foam board insulation is commonly placed between the exterior finish (i.e., siding, brick) and the studs of exterior walls. To prevent air infiltration, you should place rigid insulation boards tightly together and seal the seams with tape or caulk. However, this practice may worry some builders in cold climates since the foam board may act as a second vapor diffusion retarder. Studies have shown, however, that condensation rarely occurs in these areas unless something else is seriously wrong with the wall assembly (i.e., massive uncontrolled air leakage into the walls from the house.) If the assembly is constructed correctly, the inside surface of the foam board stays warm enough to keep water vapor in its gaseous state long enough for it to escape.
Insect Problems:
When insulating a foundation, and although foam insulation offers no food value to insects, foam board provides the potential for easy insect tunneling. Insect burrows reduce the R-value and structural integrity of the insulation. For these reasons, some manufacturers treat their foam products with an insecticide, usually a borate compound. Many building jurisdictions also mandate treating the earth around the building with insecticides and keeping an area bare of insulation board, several inches wide, and all the way around the foundation of a house as an inspection area.
A better solution for below grade walls in need of insulation is to install the foam board over the interior of the basement walls rather than on the exterior as is more commonly done. Interior applications prevent ground-dwelling insects from finding the foam board at all, and it eliminates the need for the inspection area where no insulation is allowed. However, most jurisdictions require installing a fire-barrier over the foam board. While this adds extra cost, the thermal performance of this method is superior in most cases to the more common foam board application to the exterior of the foundation. This equates with a dollar savings in energy that can repay you many times over for the additional cost that an interior application requires. If you plan to convert a basement into a living space there is almost no additional cost.
Fire Protection:
Foam insulation is relatively hard to ignite but when ignited, it burns readily and emits a dense, black, smoke containing many toxic gases. The combustion characteristics of foam insulation products vary with the combustion temperatures, chemical formulation, and available air.
Because of the dangers described above, foams used for construction require a covering as a fire barrier. One half-inch thick (1.27 cm) gypsum wallboard is one of the most common fire barriers. Some building codes, however, do not require an additional fire barrier for certain metal-faced laminated foam products. Check with your local building code/fire officials, and insurers for specific information on what is permitted in your area.
Content Provided By the DOE
Marcel
Old 5/26/07, 6:56 PM
Thanks for the information Marcel and for your reply too, Ed.
Mark
MD HI Lic # 30090
Old 5/26/07, 8:47 PM
homebild homebild is offline
Mark:
Depends on the foam type...
Depends upon the location...
Depends upon the Pennsylvania Code under which the foam was installed...
Talk to your local code office for help.
Old 5/26/07, 8:51 PM
Peter C. Russell's Avatar
Marcel, What about in an inaccessible crawl space?
Old 5/26/07, 9:38 PM
Around here, typically, rigid insulation in crawlspaces need not be covered.
Larry Kage, CMI
231 929 3525
Old 5/26/07, 9:53 PM
Roy D. Cooke, Sr's Avatar
Exposed Plastic/foam Insulation-Fire hazzard,cover, remove
Polystyrene and polyurethane insulation create a severe fire hazzard when left exposed. When ignited they burn rapidly and give off toxic fumes. Both types of insulation are considered safe when covered. Inside a house or garage,they should be covered with 1/2 inch of drywall.
Old 5/26/07, 10:33 PM
Mark, this is as easy as reading the safety label on the Product by the Manufacture and the IRC also addresses it in R314.2.3 where they state it has to be covered.
Here is a copy of the Manufactures literature that states the same.
Installation:
1. The installation process for rigid foam insulation is much like that for paneling. The material is attached to the walls with furring strips that are screwed to the walls at each slot formed by the joints in the insulation.
2. This material should be covered with a 15-minute thermal barrier such as gypsum as soon as the insulation is completely installed.
The 15 minute thermal barrier is defined by the IRC as a 3/8" drywall.
Hope this helps.
Marcel
</IMG></IMG></IMG>
Old 12/21/07, 9:33 AM
Roger A. Frost's Avatar
Roger A. Frost Roger A. Frost is offline
In Ontario the flame spread rating on any product used on interior must be not more than 150, unless otherwise specified, such as doors are allowed to be 200.
Foamed plastics are permitted if covered by sheet metal, specified thermal barrier or OSB, Particle board or Waferboard.
Hope this sheds a little light on subject for you.
Roger Frost CBCO
Barrie Home Inspector
Alliston Home Inspections
Orillia House Inspector
Barrie, ON
(705)795-8255
Insulation question mkiss1 General Inspection Discussion 6 5/28/07 8:12 PM
Insulation requirements question brepanshek Structural Inspections 17 4/1/07 5:43 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 6:25 PM
Home Warranty Attic Insulation Question jhawes Canadian Inspectors 2 12/4/06 2:54 AM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
