Old 4/17/13, 9:22 PM
Mike Corello Mike Corello is offline
Please Note: Mike Corello is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Radon mitigation system - vent system doesn't terminate about roof line
I just purchased a home with a recently installed radon mitigation system. The system vents through the basement and then upwards in a PVC pipe on the side of the house. The problem is that the vent terminates about 2/3rds of the way up, whereas my understanding is that according to EPA code it should extend at least a couple feet above the roof line to prevent re-entry of radon gas into the home. Note: I don't have any windows or doors on this side of the house.
Do you guys think I need to bother the radon system installer to have the exhaust system fixed?
Here's a photo of the system:
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/18/13, 10:07 AM
Jeffrey R. Jonas's Avatar
Default Re: Radon mitigation system - vent system doesn't terminate about roof line
Looks like the installer met the 10ft horizontal to windows rule, but it MUST still rise above the roof plane at least 12 inches.
Note: exterior systems are generally frowned upon in cold climates (I see snow and weatherized hose bibb's) from excessive condensation and load on externally mounted fans. Also note, the 45 degree angle fitting on the end of the vent piping which will exacerbate the problems by collecting rainwater and buildup of ice.
Yes... it needs to be corrected.
Old 4/18/13, 11:59 AM
Jeffrey, thank you sir very much for your thoughts. I assume then that instead of a 45 degree vent it should be 90 degrees to keep water out?
Old 4/18/13, 12:32 PM
James L. Keilson, CMI's Avatar
James L. Keilson, CMI James L. Keilson, CMI is offline
Send a message via ICQ to jkeilson
I would agree with Jeff. I do a fair share of Radon work and see a ton of mitigation systems. The discharge pipe needs to extend past the roof line as Jeff mentioned.
Jim
"We Respect Our Clients Right To Privacy"
Jim Keilson Certified Master Inspector
MarylandHomeInspectionServices.com
www.MarylandRadonTesting.org
State of Maryland License# 31141
Virginia Certification#3380 000468
InterNACHI ID: NACHI10101807
(IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Old 4/18/13, 12:39 PM
Troy Weiland Troy Weiland is offline
Agree it needs correcting. I have attached EPA recommendations.
Troy Weiland
Weiland Inspection Services, LLC
Marshfield, WI
http://weilandinspections.com
Radon Class in Oakville and Ottawa mkyriacou Canadian Inspectors 9 2/3/08 12:48 AM
Radon mitigation system at neighbors house? jsmith3 Ancillary Inspection Services & Additional Topics 3 5/20/06 9:42 PM
Radon mitigation exhaust sfalvey General Inspection Discussion 10 2/21/06 3:18 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing, Ethics & Legal Issues for Inspectors 0 2/14/06 4:38 AM
