jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Deck at rear of home. Railings exist for the deck until it reaches the hot tub in the middle. I would think rails would be needed in this area also.
Guardrail is required for any walk off >30" above floor or grade. Min. height 36"
Rick Slocum NACHI # 04072697 Elizabeth CO 80107 ABSOLUTE Home Inspection Service |
This is new construction. Be honest havent seen this set up before. I also would think a guard rail would be needed but the builder seems to disagree with me. He says its not considered a walking area.
Geez, then make it not a walking area by putting up a rail. Gotta love people.
tom |
All you can do is call it out(as a saftey issue if nothiing else). If the AHJ says it's ok then it's ok. IMHO
I guess no one will ever come out the door a little tipsy and very nearsighted on a dark night and walk right into the hot tub...or try to get out of the hot tub on the wrong side. Safety issue for sure.
If the builder is happy and can assure the client that all is well, then the client would be happy as well. I would suggest that the builder put his opinion in writing, just to protect the client. Of couse, that will probably be met with some scoffing and a little guffawing, but now the client knows about the builder. So the next place is visit with the AHJ--the fact that an occupancy has been issued attests to AHJ approval. Now, if something goes awry, the client knows who best to sue... "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Good luck suing the AHJ...most of them have indemnity, and can make all the mistakes they want. Good thing the vast majority of them do not take advantage of the indemnity.
Yes!
I have to re-check this, but I remember a 'clause' in the NEC that said the NEC indemnifies any third-party inspection. That unless omitted by the adoption, it's in-force. when I find it, I'll re-post. tom |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
It doesn't matter what code says or what the builder says. If you see a condition in which somone can be injured and you alert your client to that condition, you've done your job.
Thank you, K.S.!
If only it were that simple. When an HI reports something like this, especially on new construction, the client may hear two opposing opinions like seen here. Who is he to believe? Yes, I've 'done my job' by reporting my opinion but now that is being challenged by the builder. Should I simply ignore my client's request for clarification or should tell him I've made my opinion known and that's all I plan to do? Should I listen to his concern and questions and try to get the best answer for him as I can? Am I his advocate when it comes to interfacing with the builder? I believe the answer to the last two question is "You bet!", I'm here to explain things to him and help him work with the builder to reach the best possible conclusion. Almost invariably, when someone asks a question like this on the BB several answers come back "just report it and move on"; well, in my opinion I think that would not be serving my clients in the best manner.
yes a definite safety issue to point out to the client, but at the same time i wouldnt want a guardrail 36" high making my entrance to the hot tub more difficult. its new construction and they have taken precautions by adding a black screen fence, clearly visable in the background, therefor preventing access to the hot tub from the back door. im with richard on this one. call it out and i also agree with what jae williams had to say.
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Larry |
| Deck stairs hand railing | dshaw1 | Structural Inspections | 3 | 10/16/07 7:10 AM |
| Deck stairs railing | dshaw1 | General Inspection Discussion | 4 | 10/3/07 9:25 AM |
| I need a pic of a railing for an online course on handrails we are building: HELP! | gromicko | Miscellaneous Discussion for Inspectors | 3 | 6/10/07 10:55 AM |
| Wide gaps in outside deck railing | jbanning | Exterior Inspections | 6 | 9/20/06 6:56 PM |
