Old 4/25/10, 11:32 AM
Default Re-caulking
Here's a thread in which a home inspector recommends scraping out old window caulking before re-caulking
http://www.hawthornevillager.com/php...ic.php?t=26115
I generally just recommend to my clients that they re-caulk the gaps in the old caulking. Scraping out the old caulking can be a big job and I don't see the need.
What do you think?
Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/25/10, 11:36 AM
Default Re: Re-caulking
I agree with the Halton Home Inspector where he says:
"You should definitely cut away the old caulking. You should also fill the gaps behind the caulking with a foam insulation or even better, a foam backer type insulation. This foam backer material comes in different diameters and will provide a backing for the caulking to sit on. One of the reasons your caulking has opened is because it's just sitting over a large gap that should have been filled in the first place."
Larry Kage, CMI
231 929 3525
Old 4/25/10, 12:39 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I agree Larry, get rid of as much of the old as you can. And backer definitely helps as well.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 4/25/10, 7:45 PM
Rationale please.
Old 4/25/10, 8:02 PM
Originally Posted by jallingham View Post
Rationale please.
The old caulking is cracked and loose.
Larry Kage, CMI
231 929 3525
Old 4/25/10, 8:43 PM
iniquette's Avatar
Exactly. You are basically trying to bond new caulk to old caulk that is already loose, so you won't be getting a good attachment so to speak to get a good seal that keep the weather out.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 4/26/10, 8:35 AM
Agreed, but if the old caulking is sound and tight (just cracked) then I don't see why it needs to be removed.
Old 4/26/10, 8:52 AM
Jeffrey R. Jonas's Avatar
http://www.doityourself.com/stry/prepsurfacessealing
Old 4/26/10, 9:32 AM
Roy D. Cooke, Sr's Avatar
Originally Posted by jjonas View Post
Most old caulk does not move ( Stretch ).
Look at picture in above post and see why Backer rod is recomended ,
The thiner caulk stretches easy .
Most new Caulks ( Urethane example ) can move and stretch for years and stick like Baby poo they work great .
Old 4/26/10, 10:08 AM
Joe Funderburk, CMI's Avatar
I agree with removing the old. But I don't spoon feed my clients about how to do it. I just defer it to a competent individual.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/26/10, 10:28 AM
iniquette's Avatar
Couldn't agree more Joe. Not my job to monitor how they are doing repairs after the inspection. Unless, I am paid for my opinion.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 4/26/10, 1:24 PM
Marcel Gratton's Avatar
My windows are due for a re-caulk; anyone knows of an easy way to remove the old hard like a rock caulking?
On The Level Inspection
Gatineau, Québec
Old 4/26/10, 1:55 PM
iniquette's Avatar
Hair dryer and a scraper, and some elbow grease.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 4/26/10, 4:16 PM
Bob Elliott's Avatar
I wonder if the WD40 trick would help.
Old 4/29/10, 8:26 PM
William J. Decker's Avatar
Home inspection rule # 104. "Caulking is not flashing".
Make sure that there is backer rod or some other flashing in the "crack" before you caulk. Caulking, for the most part, is more cosmetic than waterproof.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Caulking separating between window and sill? dnasser Interior Inspections 8 12/29/09 4:24 PM
No caulking at shower wall to pan seam? hmiller Interior Inspections 11 2/9/09 7:40 PM
Toilet caulking thirst Plumbing Inspections 16 11/6/07 2:02 PM
Caulking bottom of frieze board. rmc3inspection Exterior Inspections 14 10/12/07 12:39 AM
Disclaimers dmacy General Inspection Discussion 10 1/27/06 1:02 PM
