Some of the best sources of information on comp shingles I've found are the Shingle Applicator's Manual and Shingle Technology Manual, both available for free from CertainTeed. Order them here.
The Applicator's Manual has some of the best information I've ever seen on attic ventilation. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
I tried to order the manuals, but there seems to be some error. luckily, an 800 number is provided, so I was able to leave a message.
Brian Jones, 226-662-0152 mcbridesown@hotmail.com To all newcomers, "Ceade Mille Failte" (Gaelic for "A Hundred Thousand Welcomes") |
These are great manuals and make useful reference guides too. You can also take their exams and get certifications (e.g., Shingle Quality Master and Master Shingle Applicator) and listed on their website free too. Comes in handy to be certified by the Mfr when the builder wants to argue about improper installation.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
From the website "The Art of Moisture Management" section. (My comments/insertions are in blue.) "There are two methods for moisture movement: Diffusion refers to the movement of moisture through a substance. In areas where vapor pressure is different from one side of an object(e.g., a wall) to another, moisture is diffused through the object (wall) to equalize the pressure. “High permeability” materials, such as brick, gypsum board and fibrous insulation, allow moisture to move freely. “Low permeability” materials, called vapor barriers or vapor retarders, resist the flow of moisture. Air leakage also creates moisture movement due to the water vapor that’s part of air. Moisture carried into (infiltration) or out of(exfiltration) a home due to air leakage can be 10 to 100 times greater than moisture transferred by diffusion, which is a substantially slower process. The same pressure differential factors influencing the flow of air also influence moisture flow greatly. Therefore, in an “energy-efficient” air-sealed home, much, much less moisture is released to the outside* –allowing for a potentially damaging amount of moisture to build up inside the home." ** * In this sentence, they don't mention the benefits of moisture not being released outward!!! If moisture movement by airflow (the much greater moisture "mover" and also a huge energy loss) is now severely reduced, there is very little chance of hidden condensation in walls/attics; in better cases to the point of moisture movement essentially being stopped to attics, ventilation for attics can be cut back.......less holes in the roofing/gable wall systems for water/snow to potentially leak/blow in. ** They follow with a strong negative about mositure- Moisture being held in the home can to a degree be positive by reducing the need for cold weather humidification-no humidifiers needed on furnaces. And we do have the technologies (called fans, air exchangers, HRV's) to control indoor humidities.........so why are they talking like it's still the late 1970's/early 80's- "Houses are getting too tight; gonna rot'em out and kill people with mold!!" Other notes to add to claims on their site: - Air barriers help eliminate moisture problems Notice how in the following, emphasis is on "airsealing"; keep following the leads to and on the EERE and ORNL sites!!! http://www.ornl.gov/sci/roofs+walls/...ogy%20fact.pdf http://www.ornl.gov/sci/roofs+walls/...on/ins_05.html -Their details on window flashing are weak!! |
I noticed under affiliations IACHI (International Association of Certified Home Inspectors) is listed. Certainteed courses are good for Continuing Education Credits. Do they mean INACHI?? Anybody know for sure?
Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Master Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT eCertified Inspector IAC2 Radon/Mold Certified Infrared Certified |
Courses from certainteed are accepted for CE here.
NACHI is not on the list. How do I get credit for them?
check at fastreply@nachi.org
All I've ever done is log them into the CE Log. Certainteed courses are accepted.
Mike Chris, Santa Clara, Utah
NACHI: #05051385 HouseNspect@gmail.com www.housenspect.com activerain "A man's home is his castle . . . until the queen arrives." |
I took 3 of the course from them last year, they are good and did count.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| You guys are going to love this find | belliott | Inspection Education & Training | 7 | 10/16/09 10:32 PM |
| Gasoline Prices | Rudolf Reusse | Canadian Inspectors | 301 | 8/8/08 12:17 AM |
| Extractd from the archives, Thanks Paul for this list! | jtedesco1 | Electrical Inspections | 4 | 1/2/07 7:51 PM |
| NACHI's Standards of Practice now ships free with InspectVue, and for good reason. | gromicko | Special Discounts for InterNACHI Inspectors | 31 | 5/1/06 11:08 AM |
