Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 9/19/06, 6:46 PM
Paul Dickerson Paul Dickerson is offline
Default When to Replace the Chimney Cap
I would like to get a better idea of how bad the cracks have to be in a chimney cap to recommend repairs. Would you recommend repairs to the chimney cap in the photo?
Old 9/19/06, 6:53 PM
rcooke rcooke is offline
Banned for Violating COE
Please Note: rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: When to Replace the Chimney Cap
In my area for sure water can get in water when it freezes can generate a pressure of up to 25,000 lbs per sq inch .
In order for a 1/2 in pipe to stand the pressure of water freezing it would the wall would have to be two inches thick.
It is a simple fix never asphalt it is not made for chimneys the sun breaks IT down any good fine cement based product can be used .
I also recommend a bead breaker around the chimney so the cement does not stick to the chimney so the tile can slide up when it gets warm from a fire . this can be a strip of Tape .
Roy Cooke
Old 9/19/06, 7:14 PM
Raymond N. Newman Raymond N. Newman is offline
Send a message via Skype™ to rnewman1
Besides the repair, there are a few things I would recommend for this chimney. A swep, a spark arrester / rain cap.
Old 9/19/06, 9:12 PM
Most likely, chimney caps would be constructed similar to the link below;
http://www.maconline.org/tech/constr...y/chimney.html
Marcel
Old 9/19/06, 9:19 PM
Marcel
Oh! how I wish they would be built like this . I see so few that are even close to being proper.
Some even put in a drip edge . Thanks for the site Roy Cooke
Old 9/19/06, 9:53 PM
Nice, Thanks Marcel
Old 9/19/06, 10:35 PM
Ted Allen Ted Allen is offline
Please Note: tallen is a non-member guest and is in no way affiliated with InterNACHI or its members.
It needs repair...
Old 9/20/06, 10:32 AM
nwagner's Avatar
nwagner nwagner is offline
I wouldn't hesistate to recommend repair because I never hesistate to avoid litigation.
Old 9/20/06, 4:08 PM
Is the crack big enough to get water in (YES)
does it some times freeze in this area (YES)
then it needs immediate repair to ignore a DIY $20;00 fix can soon lead to a $750.00 chimney repair .
The choice is the customers . I could care less if the follow my advice all I know is I want to make sure I reported it properly CRA
Roy Cooke
Floating Chimney Syndrome mcyr General Inspection Discussion 8 7/25/07 12:49 AM
Fireplace Enclosure jpope Interior 19 10/25/06 6:08 PM
Chimney problems mroe HVAC 13 3/30/06 10:14 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
