Old 9/12/06, 9:13 PM
sfalvey sfalvey is offline
Default Reporting correctly?
If an item is not properly installed, windows, but still works properly, how should it be reported.
The windows on this house were installed after the finish texture panel was installed. The nailing fins are on the outside of the finish material. No visable flashing, perimeter is caulked then trimmed.
There are no signs of leaking on the inside.
How would you guys report it?
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 9/12/06, 9:16 PM
Michael Larson's Avatar
Default Re: Reporting correctly?
Window is not installed in accordance with the manufactures installation instructions for window of this type and is likely to leak at some time in the future.
Michael Larson
Hudson, WI
[/I]
Old 9/12/06, 9:24 PM
Jeffrey R. Pope's Avatar
The window "still works" meaning, it opens and closes?
The window is installed to provide natural light, ventilation, and a means for ingress/egress (if it's openable). It is also a barrier against the elements (weather), which, when installed improperly, does not work.
Try this. . .
The windows have been installed without proper flashing and will be susceptible to leaks. Repair by a qualified contractor is advised.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/12/06, 9:27 PM
They do open and close, quite nicely in fact, and for now they don't let the elements in. For now.
Scott Falvey
Newbury, NH
NACHI#05051292
Old 9/12/06, 10:15 PM
Actually, Jeff, I like this better...
Old 9/12/06, 11:40 PM
gbeaumont's Avatar
Hi to all,
Scott, you could always do the
Window is not installed to manufacturers guidelines and may be a source of moisture intrusion due to defective flashings
Thing
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 9/13/06, 12:21 AM
Brian E. Kelly's Avatar
The windows are not installed properly and should be evaluated by a glazier with remedy as necessary
</IMG>
Old 9/13/06, 5:47 AM
We all are trying to put makeup on the ugly dog.
I'm considering offering The Plain Talk Report where I could just say.
"That ain't right, it needs to be fixed by someone who knows what they are doing"
Michael Larson
Hudson, WI
[/I]
Old 9/13/06, 7:33 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Exactly! Don't we wish we could say what we are really thinking?
Old 9/13/06, 7:47 AM
festep festep is offline
The only requirements for window installation in accordance with most of the Manufacturers is I.e. Fastener spacing, Fastener type, Minimum penetration of the fastener to structural member, Shim space, Sealing of the perimeter Flange or Casing. There is generally a note as to "properly flashed at the head".There are no requirements specified for triming of windows. If the window is installed in accordance with the above requirements. It servicability will be the life span of the specified sealant. It is not wise not to provide trim and additional sealing around the perimiter but the manufacturer only specifies the window installation and not the exterior trim or type of caulk.
Old 9/13/06, 7:50 AM
Sorry left out "not wise not to install trim and additional caulking"
Old 9/13/06, 11:12 PM
I guess part of my question is, if something is installed incorrectly, not to spec etc, would it be considered defective or acceptable as long as it is functioning "properly"?
Scott Falvey
Newbury, NH
NACHI#05051292
Old 9/13/06, 11:18 PM
Joe Funderburk, CMI's Avatar
My definition of what goes in the Summary is anything that: "adversely affects the habitability of the dwelling, requires repair or subsequent observation, or warrants further investigation by a qualified specialist." That definition was kindly provided by the state of NC.
I'd say the window "requires repair" and is thus Summary Worthy.
Your question about whether it is "defective" or "acceptable" is not a consideration in the way I do my reports. The important thing, in my view, is that you set criteria and be consistent.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/13/06, 11:23 PM
Good advice Joe. I have been writing reports for just over one year and I am slowly getting in the groove of consistency. I know consistency is key as long as it isn't consistantly wrong.
Scott Falvey
Newbury, NH
NACHI#05051292
Field Insurance reporting mbyrd General Inspection Discussion 3 1/5/07 4:22 PM
New Construction Reporting Software Released fo rBeta Testing! Sign up today! cdemsky Inspection Hardware, Software & Publications 14 6/3/06 11:51 PM
New Construction reporting Software Released for Beta Testing! Sign up Today! cdemsky Miscellaneous Discussion for Inspectors 7 6/3/06 12:16 PM
