Old 3/13/06, 12:04 PM
David C. Macy's Avatar
Default Retaining walls
Anyone have any good pictures or illistrations pertaining to retaining walls.
I have a client with an future inspection that I would like to be able to attach an illistration.
Thanks
Dave
Old 3/13/06, 12:58 PM
gbeaumont's Avatar
Default Re: Retaining walls
David,
what type of wall system are you talking about?
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 3/13/06, 5:51 PM
Gerry
I am not sure since I have not inspected it yet.
Was hoping someone had some pics from the illistrated home or Inspection depot.
I would think it is either block/wood/concrete.
Will post when I get a photo.
Thanks
Old 5/21/06, 1:05 PM
Michael Ends Michael Ends is offline
David
Here is a pic of an example of how not to build a retaining/garden wall . They sank RR ties then nailed on 3/8 plywood that is currently totally infested w/ termites.
Then they planted a palm tree thats currently about 30' high and leaning towards the covered patio and the house. Of course this wall is not considered an engineered retaining wall since it is only @ 2' to 3' but because of the leaning palm tree and termites I defered it anyway...
Old 5/21/06, 5:44 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
David,
Concrete Retaining Walls:
http://www.concretenetwork.com/concr...taining_walls/
A major RW contractor with various tech info:
http://www.keystonewalls.com/KShome.html
If you look up the Army Corp Of Engineers they have a series of Tech Manuals that also include retaining walls.
Remember:
Knowledge is power! But sharing knowledge brings peace!!
Old 5/23/06, 4:19 PM
dwatson1 dwatson1 is offline
Wern't the Army Corps of Engineers involved in the levee construction along the Mississippi river? Remember 1995 and 2005 levee breaks.
Old 9/5/06, 3:16 PM
Jerry B. Yost Jerry B. Yost is offline
The thread for the retaining wall company is a help.
I just booked an inspection tomorrow with a 8' tall rock and brick wall. All I can do is check for movement and take some measurments and tell the buyer of this new home that when he hires me to perform the 11 month inspection I can re-check the wall to see if it has moved.
It's amazing how this message board helps me sometimes. Kinda like youall are thinking what I am thinking and wondering.
Jerry Yost
Golden Rule Home Inspection
http://www.grhi.info
Old 9/5/06, 7:05 PM
Peter C. Russell's Avatar
What's an 11 month inspection? does it have to do with your warranty?
Old 9/5/06, 7:05 PM
Of what magnitude are we talking about??
http://www.concretenetwork.com/concr...monolithic.htm
Marcel
Old 9/5/06, 10:18 PM
Russel Ray's Avatar
Yes, Russell.
Old 9/6/06, 6:24 AM
Barry Adair's Avatar
Retaining walls are not CHEAP to install, repair, or replace.
Unless you have a good understanding of soils, compaction, drainage, and the associated physical properties involved. I see nothing wrong with deferring.
The last one I did where problems were discovered was $48,000.
Pool overflow, yard drainage, and landscape vegetation issues.
This didn't have to happen and the inspector involved will be hearing from an attorney even though it is not covered under the state or other SOP.
It wasn't disclosed nor was it mentioned or omitted in the report.
Common mistake I see around here is items not included in our promulgated report go unmentioned. This can lead to a world of hurt for an inspector.
If it is present and not inspected say this in the report and make the client aware by having them initial those items.
ie: fencing, retaining walls, fountains, any or all exterior landscape features...
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/6/06, 10:30 PM
Thanks Barry, the wall was 8-10' high and 400' long installed by the builder, it spanned the back yards of at least 10 houses. I talked at length with my client, took some measurements and told him that if he sees any sink holes or gets and ideas that the wall is moving to call me to come out and check the measurements against my original measurements. I informed my client that I am not an engineer, and I don't pretend to be one and that I could not certify or tell him that the wall was professionally built. I told him to contact an engineer if he wanted a document.
Jerry Yost
Golden Rule Home Inspections
Old 9/7/06, 8:18 AM
Jerry,
8'10", 400 Ft. long is a lot of wall, holding A LOT of expansive soil!!! Anything over 47" in height is required to have an engineered design. These plans should be on file with the local AHJ as part of the platting documents. You can also advise the client to check the plans out and speak with the builder if there are any concerns.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 4:55 PM
Best way to insulate basement walls? Bill Featherstone Interior Inspections 16 11/4/07 11:34 AM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
