Comments? Would you report on it and, if so, how would you write it up?
| Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America) |
"Ridge cap may not have been istalled in complete accordance with shingle manufacturer's written instructions, and should be evaluated by a qualified roofing contractor for possible correction." How's that, coming from a non-inspector?
Lol
Roofer may have been under the influence and Ridge cap mat not be installed in a fashion it will last, Recommend a roofer to review and estimate repairs . Please note call in the morning before the bar opens. |
I don't know Wayne, when I was in the trades a I saw roofers start drinking at 6AM and drink all day and their work was better than that. Judging from the geometric pattern, I'd say that's an LSD or mushroom roof.
"Cap shingles at the ridge were improperly installed. This condition may result in premature failure of the cap shingles. The inspector recommends correction by a qualified roofing contactor." Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Very true Very true it is one for the books
I might also add: "It is nothing short of a miracle the wind has not removed them from their present location installed in this fashion since they are not sealed to one another correctly"--- Or a short version: "Have the Cap Shingles installed correctly by a Licensed Roofing Contractor"-----(which is what I would actually put in my report)-- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Or I'd write what Kent said---
I don't know, Dale, the tickled pink part is quite nice...
This condition may result in premature failure of the cap shingles. The inspector recommends correction by a qualified roofing contactor who will tickled pink when he sees this roof." Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Roof caps at the hips and ridges should be installed using a same color three-tab shingle of the same Manufacturer or the Accessory Shingles utilized and recommended by this manufacturer for this type of installation. I would recommend a licensed Certified Roofing Company make the recommendation to repair. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I would recommend a licensed Certified Roofing Company make the recommendation to repair. I am not sure I would be so nice. Marcel - you are absolutely correct - they have used the wrong shingles. They need to be replaced by the roofing company with the correct shingles. I do not know how old that roof is, but it looks like it should still be under a warranty. I would suggest they call the installing company to correct. |
Ridge Caps are installed in an amateurish manner. In our opinion this is more prone to roof leaks or blow offs. Have a COMPETENT roofer FIX Ridge Caps properly.
Looks like the installer used laminated shingles for the ridge.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
It sort of does, Chuck, except that you can see lamination separations at some of those cap shingles.
| Ridge board check | mboyett | Structural Inspections | 5 | 6/17/09 11:49 PM |
| Number of Nails connecting roof rafter to ridge board | arook | Structural Inspections | 16 | 4/26/09 4:17 PM |
| Ridge and rafter issues/shed dormer | Adam J. Deangelo | Structural Inspections | 1 | 5/16/08 3:30 PM |
| Rafter to Ridge connection | rskinner | Structural Inspections | 17 | 8/26/06 8:33 AM |
