Old 3/14/07, 7:16 PM
tneumann's Avatar
tneumann tneumann is offline
Default Ridge Vent
I haven't ever seen a ridge vent like this one..(which doesn't make it rare)..anyone?
Old 3/14/07, 7:26 PM
tdietrich1's Avatar
Default Re: Ridge Vent
First time for me, so I have to ask some questions:
Looks like steel, is it stainless?
Is it a home made job, since I see no baffles?
I guess if I was taking sheet metal course I would love to make my own ridge vent too.
tom
Old 3/14/07, 7:32 PM
We installed lots of those back in the 70's but brown. I believe they were aluminum...dented easily...also, when the wind was right they permitted snow/water entry but a better baffle helped that.
Larry Kage, CMI
231 929 3525
Old 3/14/07, 7:34 PM
tneumann's Avatar
Yes it was an aluminum type material.....did they always get installed w/ exposed nails?
Thanks
Old 3/14/07, 7:36 PM
tdietrich1's Avatar
Ah,
I had an alum ridge vent, the nails were covered in roof cement/tar. Just little dabs of it.
However, not the same here, mine where black, had a wind baffle, and were installed in 93.
Just a guess from the photo, were they steel nails, they look rusty.
tom
Old 3/14/07, 7:37 PM
Thanks
Yes, at that time and being dark brown, we just dabbed the nails with a little tar.
I liked it better when the shingle over vents came out.
Larry Kage, CMI
231 929 3525
Old 3/14/07, 7:49 PM
Yep. That is the way it was. Didn't work to good in Northern Maine. ha. ha.
Too much snow.
I guess Larry must have come to Maine. Could we say that particular ridge vent design was like the Crescent Wrench.
Marcel
</IMG></IMG>
Old 3/14/07, 7:55 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
they used to make them in mill finish aluminum & brown. 10' lengths. end caps & connector pieces sold separately. i don't remember if the nails were exposed or not.
Old 3/15/07, 11:11 AM
David P. Valley's Avatar
Every time I see these aluminum ridge vents, I normally see leaking and tree debris entering at the ridgeline. I always recommend upgrading to a more improved ridge vent.
Preferably....this one or this one
Old 3/15/07, 6:08 PM
Like your first option Dave. Works real well.
Marcel
Old 3/16/07, 12:47 PM
dhelm's Avatar
dhelm dhelm is offline
The question seems to have been answered. This is a case of the industry improving things through negative experience. I also have installed a number of these (in the 80s)
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 3/18/07, 12:25 AM
lfoster's Avatar
lfoster lfoster is offline
More common for metal roofs? but,,, it doesn't have the same ripples that R-panel or standing seam would have.
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 10:17 AM
Ridge vent recommendation cobarr Exterior Inspections 9 1/30/07 5:15 PM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 6:22 PM
