Is this right for the shingles on the ridge vent?
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Using field shingle, like those, is not a good idea.
The manufacturers will let the installer make ridge caps when single layer shingles are used but multi layer type, no. They tend to crack and delaminate. They make regular cap shingles for that. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Are those laminated shingles or are they like certainteed horizons that look like they are laminated ?
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
there is a special cap shingle for laminated shingles....they cost more and some may tend to not use them for that reason, but as Larry said that can be a mistake....
In my area, everybody cuts three tab shingles for ridge cap. I have not seen any problems yet with the three tab method.
Ridge caps from
CertainTeed; http://minnesotaroofing.com/Roofing_..._and_ridge.htm Gaf; http://minnesotaroofing.com/Roofing_...e_shingles.htm Owens Corning; http://minnesotaroofing.com/Roofing_...e_shingles.htm IKO; http://www.iko.com/shared/residentia...HipRidge12.pdf http://www.iko.com/shared/residentia...ochUltraHP.pdf Most all Manufactures have a ridge and hip cap shingle made for the pupose. Not installed per Manufactures Instructions. Will either fail or void warranty. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Purpose-manufactured cap shingles are better, but if caps are cut from 3-tab, they should be cut in such a way that the adhesive strip works effectively to bond the end not nailed.
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 2:23 AM |
| Air Vent Inc. "FREE" Seminar in Toronto | mkyriacou | Canadian Inspectors | 10 | 2/13/09 11:30 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 6:22 PM |
