gmathias is a non-member guest and is in no way affiliated with InterNACHI or its members.
I found a ring attached to the roof. It looks as though it is attached to a bracket on a roof truss. I expect that it was a part of the installation process, but why was it left behind? Shouldn't it be removed?
I agree it was for safety tie down. Unfortunately, OSHA Standards for a Life-line hook-up has to be rated for 5000#. I would still hook up to that rather than slide off the roof.
Nice to see that the OSB was manufactured in Easton , Maine. About the few industries left in this Aroostook County other than Paper Mills and those are closing everyday. Marcel </IMG></IMG></IMG> |
How about a make shift flag pole holder?
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
That looks like a standard guy wire hookup for an amateur short-wave radio antenna. I have a lot of them around here because there are a lot of short-wave radio guys operating here, especially when Mother and Father Nature come a-callin' (wildfires, earthquakes, and mudslides). We also had a lot of short-wave radio operators in Texas for hurricanes and tornadoes.
Looks like it is about a foot and a half down from the ridge to me.
Marcel |
Nice and handy to the light bulb for heat never have much ice on it if they leave the light turned on. Roy Cooke . Royshomeinspection.com |
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
I understand the safety issues here but in my mind if the roofing guys leave them exposed it is just a leak waiting to happen. Tuck them under the sheeting and be done with it.
Larry |
Or use the safety bracket that you see below and remove it when done working on the roof.
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=24366# ![]() ![]() ![]() ![]() ![]() ![]() Catalog Quick OrderOrdering InformationCustomer ServiceView/Track OrdersCheck Out 0 Items In Your Cart![]() ![]() ![]() ![]() ![]() ![]() /************************************************ Cool DHTML tooltip script- © Dynamic Drive DHTML code library (www.dynamicdrive.com)* This notice MUST stay intact for legal use* Visit Dynamic Drive at http://www.dynamicdrive.com/ for full source code********************************************** */var offsetxpoint=-60 //Customize x offset of tooltipvar offsetypoint=20 //Customize y offset of tooltipvar ie=document.allvar ns6=document.getElementById && !document.allvar enabletip=falseif (ie||ns6)var tipobj=document.all? document.all["dhtmltooltip"] : document.getElementById? document.getElementById("dhtmltooltip") : ""function ietruebody(){return (document.compatMode && document.compatMode!="BackCompat")? document.documentElement : document.body}function ddrivetip(thetext, thecolor, thewidth){if (ns6||ie){if (typeof thewidth!="undefined") tipobj.style.width=thewidth+"px"if (typeof thecolor!="undefined" && thecolor!="") tipobj.style.backgroundColor=thecolortipobj.innerH TML=thetextenabletip=truereturn false}}function positiontip(e){if (enabletip){var curX=(ns6)?e.pageX : event.clientX+ietruebody().scrollLeft;var curY=(ns6)?e.pageY : event.clientY+ietruebody().scrollTop;//Find out how close the mouse is to the corner of the windowvar rightedge=ie&&!window.opera? ietruebody().clientWidth-event.clientX-offsetxpoint : window.innerWidth-e.clientX-offsetxpoint-20var bottomedge=ie&&!window.opera? ietruebody().clientHeight-event.clientY-offsetypoint : window.innerHeight-e.clientY-offsetypoint-20var leftedge=(offsetxpoint |
Well, I guess I screwed this one up. ha. ha.
Marcel |
Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Briefly read y'alls notes. Is it a guy wire thinga ma giggie? Never see them leave roofing jacks here. It did look like a very walkable pitch though and probably only a two story at most, so leaving a safety jack seems like a waste (unless it's a code to leave it) especially since they will only caulk it where it penetrates the roof which may end up leaking.
Peter Doane Realty Check Inspection Service NACHI ID# 05120681
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/23/09 11:52 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
