I did an inspection of a condo in a big complex today. Brand new building built in 2007. I don't do too many inspections of rubber roofs around here. The roof had several ripples in it. See pic for example. Is this poor installation, or is it pretty normal. How would you write up this condition in the report? Deficient or serviceable. Thanks in advance for any help.
It just hasn't been pulled tight or rolled out properly to take the wrinkles out.
Will it affect performance? No, not unless the roof is walked on or used as a deck and someone happens to catch the wrinkle and rip it. |
I don't write up minor ripples at the edges, as not many roofers' are perfect. What you're inspecting for is tightness to the underlying surface with no major air pockets throughout the field. If I observe big air pockets, I write it up for repair. All rubber should be securely glued down...Period.
Also, check every seam for gaps. If seams are becoming loose, water will seep into this area and cause major problems. Another major issue I usually find in rubber roofs is drainage problems. Write up any major puddling. Here'a a great guide on Rubber Roof installation... http://www.flatroofsolutions.com/installation.html Last edited by dvalley; 6/6/07 at 4:29 PM.. |
Ditto Ditto Good advise David. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Your rubber roof here looks as if it is used as a deck area. If so those ripples area trip hazards by the railing. Yes, not all roofers area perfect, but in areas such as this they need to be. They can be sloppy else where.
Scott A. Figert www.sfigert.com www.nachi.org NACHI #06042595 Figert Building Inspection, Ltd. (419) 399-4472 Office & Home Sweet Home |
No walking on rubber roofing. |
Any flat roof I've inspected with any type of material, if there are ridges, ripples, they are deteriorated MUCH more than the rest of the material, so if I see ripples on a flat roof generally it is not cost effective to repair them, I simply tell my client to expect those areas to fail at a faster rate than the rest of the material, and replacement will need to done at a premature age of the material. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
i don't think all rubber roofing is fully adhered. some is mech fastened, some ballasted.
i don't think the minor ripples need to be called out. it may not even be a roofing application problem. the building could have moved since the roof application. seams, punctures and flashing are usually the problem areas. |
EPDM roofs can be installed in a variety of ways, and the most commen is the fully adhered.
Some of the Inspections of the EPDM roofs as done by most Building Maintenance people would be as listed below. EPDM Inspection Insights When inspecting an existing EPDM roof system, roofing consultants, maintenance and engineering managers and other individuals responsible for a building’s maintenance and performance should look for these conditions:
It is also important to trim or cut the edges of the EPDM patch so the splice or patch is slightly rounded, thereby leaving no sharp edges to peel back and disbond. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm in agreement with Dale and Marcel. I'd write it up, if for no other reason then for the fact that the sun will deteriorate the surface here faster. That ol' Mis'sip'i sun is about as bad as the one in Arizona! Also, look carefully at the drainage associated with this particular area. If it retards drainage or causes pooling here, that is an issue.
Thats strange I would have thought a EPDM membrane would have UV stabilizers in the material to prevent membrane breakdown fwiw.
Simply note any inconsistencies (ripples) and move on. In my book...small ripples aren't no big deal. |
I agree with that statement also.
I agree with David Valley and Marcel Cyr that small ripples aren't a big deal. I have been a Project Supt. in commercial and industrial construction for over twenty years and have used EPDM on many projects. As long as water flow is not restricted or has little restriction, it should not pose a problem as long as the seams and roof penetrations are properly sealed.
Harold,
Welcome to iNACHI. You just dug this post up from last years threads. You must be doing your research. |
| Asbestos | jlybolt | Exterior Inspections | 41 | 7/17/07 1:13 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| rubber roof | brepanshek | Exterior Inspections | 4 | 3/5/07 6:35 PM |
| NACHI Chicago Education Meeting - Roofing | wdecker | Inspection Education & Training | 0 | 10/5/06 11:03 PM |
