No one asked me first.
| Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America) |
What the hell.....
High winds ? |
Torch down to osb w/out a base sheet(upon zooming in a bit, looks like maybe there was a base)? Or is it just plain old rolled roofing.
I've heard a few roofers argue that torch down (if that's what it is) is more wind damage prone on areas with a slight pitch like the area that pulled up, when a base sheet IS installed. Dunno. Was probably your fault anyway, as you were last person up there. Did your ladder tear up the edges? Snazzy looking parapet walls though. |
Just like the title says Rolled roofing.
Does the lack of scuppers turn the cumbustion vents into overflow drains? You don't often see water features lined with roll roofing.
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Flat or rolled roof comments? | crichiii | Exterior Inspections | 0 | 9/20/06 10:45 AM |
