| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
A 2001 house, several on the street looked the same. Would you call it out? What would you call it? It looks like too mucg shingle is exposed.
John Shishilla Residential Contractor Accredited Claims Adjuster (ACA) Serving all of Brevard including: Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Cape Canaveral, Indialantic and surrounding areas. Honor Construction www.honorconstruction.com www.honorinspections.com "Brevard's Premiere Inspection Company" 321-327-2950 Last edited by jshishilla; 3/18/09 at 4:24 PM.. |
| Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America) |
ccurrins is a non-member guest and is in no way affiliated with InterNACHI or its members.
WTF?
Haven't you seen 'Zebra' shingles before?
(I especially like the ramped vent) And is it just me, or is there a flashing issue at the wall transition? "You cannot depend on your eyes when your imagination is out of focus"...Mark Twain Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota NACHI07013103 IAC2-01-1567 |
Flashing issue? Here is a better angle.
John Shishilla Residential Contractor Accredited Claims Adjuster (ACA) Serving all of Brevard including: Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Cape Canaveral, Indialantic and surrounding areas. Honor Construction www.honorconstruction.com www.honorinspections.com "Brevard's Premiere Inspection Company" 321-327-2950 |
appear be totally appropriate shadow ridge cap from Certainteed
scroll down http://www.startremodeling.com/roof_installation.htm there are many FREE product installation and identification courses available on many materials i highly advise all in this profession to take advantage to become a cut above your competition http://www.certainteed.com/professio...ders&index=2#2 badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good Last edited by badair; 3/18/09 at 7:28 PM.. |
designed to be used with laminated shingles...nothing structurally wrong, but would be much more cosmetically pleasing on a dimensional roof....
Thanks guys that is what I was looking for.
Well I don't understand.
The ridge cap shingles are offset to the right, probably to make up for the way the exposures worked out on each side. That didn't look like a problem to me. Can anyone cite one? IRC? Manufacturer? But that ventilator-looking thing on the right had a crack in it which will leak. I don't know what that thing is, but I'd call out the crack for repair to avoid moisture intrusion. Ridge and hip cap shingles also show excessive amounts of adhisive strip exposed, meaning they will fail to adhere to each other adequately. If they are in a high-wind area, they will blow off. Defective installation- call it or be wrong. Guys, I must be crazy. I see no problems where you see them and you see none where I see them. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 Last edited by kshepard; 3/21/09 at 3:10 AM.. |
No step flashing. It's wrong.
Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 |
AAAARGGHH!!!! Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) EXPERT WITNESS Director of Green Building Director for International Development (303) 717-8940 (303) 258-8289 Last edited by kshepard; 3/21/09 at 3:23 AM.. |
Barry - I thank you for taking the time out to send the link. I find it helpful to be sent to the page and maybe have to scroll for a minute or two, so many times I have learned other things along the way. Too bad other cannot spend a minute or two in looking for infomation and want everything specifically spelled out. This is a message board I thought. People complaining of other help is what stops people helping. I remember when the Mr. Abernathy and Mr. Ray used to help ALOT....they took their personal time from their lives to help another the best they could with the payment of NOTHING in return and they get blasted. No wonder why the posts and advice are down.
Kenton,
That is not a crack, it is tar. As far as the flashing goes, it is probably there and goes under the shingles. Very common. Bill Siegel Florida Home Inspection Team Inc. |
Kent,
the correct info provided and directions to locate were so easy my monkey could find them, try again bro' Russell, No PROBELMO! badair ADAIR INSPECTION 972-487-5634 Residential-Commercial-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes...accept the good Last edited by badair; 6/2/09 at 1:54 AM.. |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Services & Additional Topics | 12 | 2/13/08 12:33 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior | 9 | 2/15/07 2:19 AM |
