Has anyone inspected this type of roof covering before. This is the first time that I have come across this. It appears to be material and although the roof is fairly new, I wanted to know what to look for other than the obvious on a roof that has this type of roof covering.
Ran into something similar last week. Only mine looks like it was installed after the beer run.
![]() Or maybe they started earlier ![]()
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
There are also elastomeric, PVC, poly, acrylic, rubber... coatings that can give this appearance depending on material application is applied to. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Thanks. You nailed it! I never saw this applied to a home before. It looks really good on this home. Are there any major disadvantages?
Almost looked like that closed cell foam. Did it feel spongy at all? Hard to tell by picture, the mobile home and similar coatings have a different appearance than the foams.. I've seen the foams applied on a few residences here and there.
I have limited experience with the foams except that there are some desireable qualities with it? Could be the mobile home coatings that Barry mentioned as well. Here's a link if you were curious about the foams http://www.sprayfoam.com/spps/ahpg.cfm?spgid=7 AHHH, a closer look at the picture by the satelite dish, looks like the coverings Barry mentioned. Disadvantadge? To me they would require more maintenance than a composition or other type of roof. Just me. Maybe the newer elastomerics will go a little longer. Tim Home Inspections in Palmdale Lancaster California Tim Spargo Spec Rite Inspections Commercial and Residential Inspections Palmdale Lancaster Santa Clarita CA 661-317-5770 Last edited by tspargo; 7/4/08 at 2:39 AM.. |
I wish the moron cable guys would not pick those stupid dishes on the roof deck.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
For those wanting updated roofing systems information you can subscribe to www.professionalroofing.net I get their monthly mag and find some of the articles useful for system identification and inspecting as well hth ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
That dish installation is a leak waiting to happen, unless they installed it in a pitch pan, which I doubt.
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| New Roof covering | rcooke | Canadian Inspectors | 2 | 3/25/06 4:26 AM |
