Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is a one quarter inch nail penetration through roof deck a roofing defect? I would think it's just a less than professional job only. Just curious.
Erol...with 7/16" osb being used as sheating I'm suprised when i don't see a few coming through...jim
Just my never to be humble opinion Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Standard for most material around here is through all materials and a minimum 3/4" penetration into deck or through materials and deck if less than 3/4" deck material is used.
This is different in wind storm or seismic regions as I recall ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 4/21/08 at 11:11 PM.. |
One good thing about OSB roof decking. It blackens real easy when there is a roof failure and gives the client (if they check the attic, annually) a good indication of roof failure. Again, just my opinion. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Roofing Nails
Your roofing nails should be long enough to penetrate your roof deck 3/4" or they should go all the way through your deck if it's less than 3/4". For instance, if you have 1/2" plywood for a roof deck, your roofing nails should go all the way through and poke out in the attic. Please be advised that it can be difficult to find roofing nails longer than 1-3/4" in length. Up here, typically use 5/8" roof deck with H-clips or T&G. Nothing less. Nail length for new roof, would be 1&1/4". Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Yes, 1 1/4" is what we used on a new roof. They penetrate the correct amount and were easy to shuck from a handful to between the index and middle finger for the first blow.
Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is the page from asphaltroofing.org otherwise known as ARMA
http://www.asphaltroofing.org/pdf/tb_221.pdf Ed |
Thanks Ed. Got the information I needed to make sure 1/4 '' visible nail penertration viewed from attic was acceptable.
9.26.2.2. Nails (1) Nails used for roofing shall be corrosion-resistant roofing or shingle nails conforming to CSA B111, “Wire Nails, Spikes and Staples”. (2) Nails shall have sufficient length to penetrate through or 12 mm into roof sheathing. (3) Nails used with asphalt roofing shall have a head diameter of not less than 9.5 mm and a shank thickness of not less than 2.95 mm. (4) Nails used with wood shingles or shakes shall have a head diameter of not less than 4.8 mm and a shank thickness of not less than 2.0 mm and shall be stainless steel, aluminum or hot-dipped galvanized. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 11:50 AM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 3:05 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
