Roof today has the 8" drip flashing sticking out 2-3" beyond the edge of the shingles and 1-2" beyond the edge of the fascia. Outside of being ugly and not installed right, do you see any problems that will be caused?
I wonder if it was an after thought when they realized the shingles didn't make it all the way to the edge of the roof? Thanks, Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Judging from your photo it is just one of several indications the roof was not installed by a professional. Those shingles look like they were laid down by a couple of drunks. There is no telling what else was done improperly that you can not see. Proceed with caution!
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Before thought, during thought, after thought, irrelevant it's just wrong and outer course of shingles requires tear off and CORRECT reinstallation. While they are doing this they can very easily also install proper drip edge flashings
man if all of these were the same house, you got one messed up inspection, hope you charged enough ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
BINGO-I did OK, it is a small 2 bedroom single bath cabin. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
How do you like the vents through the roof?
This is DIY at its best!
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
ACME Hack-em at your service!!!
Hi Scott, Hows it going? |
Tony Coelho is a non-member guest and is in no way affiliated with InterNACHI or its members.
No Jack that is DIY at its worst!!!
Hey Peter,
Been a long time. Things have been good so far this year but slowing down. How's things in your neck of the woods? Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
For some reason after looking at the pic, I'm think major leaking for starters? I've seen the shingles cut back a 1/4 to 1 inch but several inches from the edge? Here's ur sign
Good to hear from you. |
The roof is shrinking!!!
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Lack of aluminum drip edge | Brenda | Exterior Inspections | 26 | 6/16/06 7:28 AM |
