Old 1/23/06, 11:06 PM
Peter Foxe Smothers's Avatar
Peter Foxe Smothers Peter Foxe Smothers is offline
Default Roof Flashing
Am I correct in beliving that the roof where it meets the brick should be flashed in this picture?
Thanks!
Old 1/23/06, 11:16 PM
gbeaumont's Avatar
Default Re: Roof Flashing
Hi Peter,
the quick answer is yes/probably, it should have a "kick-out" flashing, is this a full brick veneer or a "stick-on" it looks like the former
Regards
Gerry
Old 1/23/06, 11:27 PM
Its a stick on. This is a new build. Anyone else? Getting ready to finish the report and want a few more responses before I call it out to the builder.
Old 1/23/06, 11:42 PM
Dale Duffy's Avatar
If the home was in Phoenix, but it is not, flashing would not be required there.
Old 1/24/06, 12:08 AM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
i'd report, "small section of roof should have kick-out flashing to prevent wash up of debris and cause water damage"
Old 1/24/06, 6:18 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
I believe the water mark below the window will answer that question. Good building practice to have flashing and kickout
Old 1/24/06, 6:32 AM
CarlBrown CarlBrown is offline
Please Note: CarlBrown is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www.dryflekt.com
Old 1/24/06, 7:28 AM
Adam J. Slimack Adam J. Slimack is offline
I'd start with gutters and downspouts...
Adam, A Plus
Old 1/24/06, 8:27 AM
gmartin2 gmartin2 is offline
Please Note: gmartin2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Up here in MN its a good idea to use flashings in that area. It will pass in the summer but when it snows and you get ice dams........at night when things are quiet you will hear dripping. Of course proper insulation to achieve a cold roof helps. 'there's never time to do it right, but always time to do it over'
Old 1/24/06, 8:47 AM
gbeaumont's Avatar
Hi Peter,
with it being a stick on veneer the use of proper flashings is critical.
Regards
Gerry
Old 1/24/06, 8:57 AM
Carl A. Brown's Avatar
If they skipped the flashing detail! What did they do to the moisture barrier?
Old 1/26/06, 6:25 AM
What it really needs is gutters. Yes, it should have flashing, but you'll almost never see it installed in that situation. Slotting brick for counter-flashing VS NOT doing that = the least of his problems.
If the darkness below the window is from moisture, where's the dark trail from the roof edge?
-Kent
Old 1/26/06, 8:19 AM
lagudo lagudo is offline
Please Note: lagudo is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree with the above. There was no oversight on the job or the crew just got lazy. Whatever it is its wrong and should be repaired.
Louis Agudo
Home Sweet Home Inspection Services
Old 1/26/06, 8:25 AM
Anything short of a kick out being installed is a bandaid and will over time fail!
And IMO it is the roofers fault it was not in place. Then the builder,then the lick and stick brick installer! Where was code inforcement?
And if the kickouts are not code can anybody tell me how to help get it that way?
Old 1/26/06, 9:46 AM
Dale Duffy's Avatar
Carl, in Phoenix they make their own codes and change existing on a daily basis.
I have never seen flashing in the area pictured above unless it was done in the old days when craftsman used to exist.
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
Questionable wall to roof flashing dbucknavich Exterior Inspections 4 8/14/06 12:57 PM
Patio Roof Flashing tneumann Exterior Inspections 16 3/24/06 8:47 AM
