Old 9/24/09, 1:08 PM
nbhi's Avatar
nbhi nbhi is offline
Default Roof Height?
What is your tallest ladder you have? I have been coming across
roofs that are 30' ft. plus and my ladder is not even close.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America)
Old 9/24/09, 1:40 PM
arook arook is offline
Please Note: arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Roof Height?
My tallest is 28'.
Most roofs I come across, I can get onto a lower roof and then piggyback onto the upper roof. So it's rare that I need my 28' ladder.
Old 9/24/09, 1:43 PM
Joe Funderburk, CMI's Avatar
17'. If it's taller than 1 story, I'm not climbing on it anyway.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/24/09, 3:20 PM
David P. Valley's Avatar
A four foot step-ladder is all I need...
Old 9/24/09, 4:19 PM
nbhi's Avatar
Joe
What do you tell your client. Do you defer the roof to a roofing contractor since you don't go up? I do use binoculars,but there times when you can't see the roof from ground level.
Old 9/24/09, 4:28 PM
Attachment 32114
That is just my size David, I like it.
Old 9/24/09, 4:33 PM
Try this...... it works for me.
Old 9/24/09, 4:41 PM
That used to work in my dreams as a kid too!
Old 9/24/09, 4:57 PM
Christopher Currins's Avatar
Ask Ben what he uses?
http://www.nachi.org/forum/f13/going...tml#post562417
Christopher Currins
Certified, Licensed
Old 9/25/09, 5:45 AM
nbhi's Avatar
Here we go again. You ask a question and you get a comedian answer.
You need to take your show on the road.
Old 9/25/09, 7:02 AM
Wayne B. Wilson's Avatar
I use a camera pole from the ladder Scan the roof with video and , binoculars Check the attic
Old 9/25/09, 10:07 AM
nbhi's Avatar
Wayne
Camera pole? Do attach a camera to a pole and id so what do you use?
Do you have a pic?
Old 9/25/09, 2:30 PM
Originally Posted by nbhi View Post
Joe
All my reports have this statement included at the beginning of the roofing section. "If we do not walk the roof, and we are not required to do so, the limitations of using binoculars or ladders at eaves is that the upside of chimneys, flashings, dormers, etc. may not always be visible. "
If I cannot see a certain section of the roof with binoculars (say the rear), then I specifically disclaim that section of it in the report and recommend a further evaluation by a competent roofer. That practice has never been a problem for me in > 4 years and > 1000 inspections.
Theodore Roosevelt
Joe Funderburk, CMI
Old 9/25/09, 4:26 PM
Just being realistic,
P.S. I've answered a few of the MANY questions you've asked over the yrs. with accurate answers, some when I was a member, and I was never once thanked for it.
Christopher Currins
Certified, Licensed
Old 9/25/09, 5:24 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Screw a 1/4-20 thread machine screw to wood screw adapter into the end of a telescoping light bulb changing pole. Drill a hole through the pole and tie a clip on there. Attach your camera and set it in video mode and extend it up to the roof. Review the video there on the spot or download it to your laptop.
I run into that situation all the time with row homes because I only carry a 28 foot ladder. Erecting a ladder any bigger than that by yourself can be dangerous. I thought there used to be something in OSHA guidelines related to the length of a ladder a single person can erect, but I can't seem to find it. I know many fire rescue companies limit it to 28 feet because a longer ladder can get unweildy and easily get away from you.
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 6:31 AM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
