Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 8/24/06, 6:27 PM
David C. Macy's Avatar
Default Roof Question
Is this a roll asphalt roof covered with a roofing sealant? The roof has poor drainage/cracking and appeared to be installed by Joe Hman.
I am trying to report the correct words for my report.
Thanks
Dave
ID:	5250   roof-question-79606-s.euclid-009-small-.jpg.jpg
Old 8/24/06, 6:46 PM
Dale Duffy's Avatar
Default Re: Roof Question
Looks like mopped/rolled on Asphalt Roof Emulsion.
Should have a reflective roof sealant on it, but it costs more than the emulsion.
Old 8/24/06, 6:58 PM
rwand1 rwand1 is offline
The first photo indicates this flat section holds water and patched, and will have a higher propensity to leak. Budget for replacement.
The discharge of the downspout is poor and should be extended to the lower eaves. The area exhibits damage to the roofing material and if left unrepaired will result in leakage.
Old 8/24/06, 7:01 PM
Dale Duffy's Avatar
Oh...and it also looks like it needs to be replaced.....
Old 8/25/06, 1:16 AM
John Nosworthy John Nosworthy is offline
Looks like 2 ply's of hot mopped felt, with a flood coat. Doesn't appear failing anywhere, no mention of leaking, flashing requires periodic maintenance, consider having a qualified roofing contractor evaluate.
Old 8/25/06, 8:13 AM
Why would you recommend further investigation if the roof doesn't appear to be failing and periodic maintenance of flashing is required and there are no leaks? If its a flood coat it would require ballast to protect from UV.
Old 8/25/06, 8:16 PM
mrowan mrowan is offline
Please Note: mrowan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Fellows
Who really cares what type of roof it is in this instance.
This type of roof has not been used for over 10 years, typically has a life expectancy of 10 – 12 years and therefore needs to be replaced in the very near future – now!
The photographs appear to support this generic approach
“Roof has reached the end of its function life and budget for replacement” in short.
I am sure the actual inspection findings on the inside and outside will support this also, from repairs, missing ballast, ponding, drainage, creasing, cracking etc. etc.!
These are the easy ones to report on!
Watch out for vinyl residing over original siding also. Looks like you have sme issues there also!
Michael
Old 8/25/06, 8:26 PM
Steve Boozer Steve Boozer is offline
Please Note: Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like smooth torch grade modified bitumen on the flat and then they installed granulated 90 lb roll roofing on the steep roof coming down to it and tarred it where it joined. Obviously a poor installation from the wrinkles and tar. But just cause it's ugly may not mean it's leaking.
Old 8/26/06, 9:41 AM
Larry Ewens's Avatar
Larry Ewens Larry Ewens is offline
Send a message via AIM to lewens
IMHO
there are only 2 types of flat roofs and their coverings, those that leak, and those that are going to sometime in the future.
Larry
Larry Ewens
1578 Colborne St
Brantford On
Nachi ID #05022485
Just my usual 12.5 cents
http://acissbrant.blogspot.com/
Roof Repair? Maybe NO jhagarty Exterior 9 2/15/07 2:19 AM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 3 1/22/07 11:24 AM
Wood shake roof question jclark1 Exterior 4 9/11/06 10:23 PM
Attic ventilation question pdoane Interior 8 8/27/06 3:22 PM
Ladder safety by Rick Bunzel gbeaumont Misc. Discussion 9 3/24/06 6:24 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
